Question about Sony CDP-C445 5-Disc CD Changer
CD tray opens and closes by itself. Will not play a CD because it opens up. when it opens it acts as if it is trying to exchange discs because it cysles left and right. Has it lost its mind and is there a way to reset the electronics?
AREA51S4B
  • 30 Answers
SOURCE: Tray will not stop opening and closing
You have to open the cabinet ..with the power off!! with tray open look at the laser it should be in the cd home position..move the laser toward away from the spindle motor or turntable.you should see a switch with a cover over it,it may be black or white or clear..the is your laser home switch..with your finger or small screw driver gentely push the switch towards you or bend it towards you.with the cover off.plug the unit up.Watch the laser as it moves away from you towards the cd spindle, it it stops and the tray moves in, and the cd mech chucks .you should see the laser turn on and see the objective lens move up and down..if it does not..and it continues with your original problem the you have to retime the tray and loading gear..try this first..
Posted on Nov 05, 2008
  • 133 Answers
SOURCE: cd tray stays open
There could be damage to the tray contact switches
(these tell to the control unit the position of the tray - open/closed), so that the control unit can start/stop and reverse the direction of the tray ejector motor.
These contacts are located somewhere underneath the tray (usually near the front unit cover), and since you mentioned that the tray was bumped while it was open, it is possible they were damaged. Also, the behaviour of the tray suggests that the control unit can no longer tell whether the tray is open or closed so it operates the tray motor in a wrong manner, which, again, points to these same contacts as the possible cause.
Repairing the contacts may be a somewhat delicate procedure, first you need to locate them (it may require partial disassemby of the tray mechanism), if they are bent a pair of tweezers might do the job, if there's hard damage, it's probably better to replace them (scrapped CD ROM units or a dead CD unit might be a good source, they just need to be of the same dimensions).
There may also be other causes for this malfunction, i just mentioned the first thing that i would check.
Hope this helps somehow.
regards
3rq8 (Triarcuate)
Posted on Jul 16, 2009
carputers
  • 255 Answers
SOURCE: I have a sony 5 disc cd player. The cd tray will
motor is wearing out, or belt is slipping, or teeth are worn down
Posted on Sep 08, 2009
micromatikal
  • 2777 Answers
SOURCE: In 2001 I purchased a
This is a fairly common problem with discs changers. The laser has failed or is too dirty to read the discs. You can try a laser cleaner such as:
http://www.amazon.com/gp/product/B00000J1QK?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B00000J1QK
But otherwise you will just need to replace the unit.
On rare occasions blowing canned air inside the unit towards where the discs are when they spin could free it up, but it is far better to use an actual laser cleaner. They almost always take care of the issue.
Thanks
Tim
Posted on Sep 09, 2010
  • 99 Answers
SOURCE: CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Posted on Sep 12, 2010
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
Drawer closes by itself
The loading mechanism is off by a tooth or 2. The tray out position switch is not being triggered properly and the tray will reenter the machine. Did this just start happening? It is possible that the sensor switches are defective too. Worse case scenerio is about $5 in parts plus the local labor rate for repair.
Dan
Mar 28, 2008 | Pioneer HTD-520DV System
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
Nov 18, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
CD opens and closes perpetually. CD won't play.
likely yes. does not sound like coincidence. try this: search ebay for an AS-IS item for $1 and use it for part-swapping. first to swap-the main circuit board holding the micro chip.
Jun 04, 2007 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
96 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
