I have a Tempstar 9000 airconditioning unit and while I was weed wacking I accidently cut a wire to the unit. I replaced the wire but now the unit wont turn on and also my furnace blower wont work even in the "on" position. I have a energy saver unit attched to the a/c unit as well. One wire connects to the a/c unit and the other to the energy saver. If I push the connector on the unit with the panel off the unit will run. Cansomeone tell me how to connect those four wires?
  • 455 Answers
Hello TLOEKS You blew the transformer FUSE inside the blower unit! It should be a 5amp blade fuse like the one that goes in a car.It is located at the curcit board at the blower compartment.Replace that to restore low voltage power and every thing will work.Strip back the wire and match color to color to resplice it make sure that they will not touch at any time or the new fuse will blow too.wire nut or electrical tape the wire repair.
Posted on Aug 23, 2010
Testimonial: "ROWYCO! That was awesome thanks for the help, its 95 degrees here and I was going to die if I didnt get my a/c fixed, total cost was 80 cents!"
Replace head on toro model #51954 curved shaft trimmers
https://video.search.yahoo.com/yhs/search;_ylt=AwrTcdIyalFXg.QAUmAnnIlQ;_ylu=X3oDMTByNWU4cGh1BGNvbG8DZ3ExBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=Toro+Model+51954+Weed+Trimmer+Owner+Manual&fr=ytff1-msgr&hspart=mozilla&hsimp=yhs-006
Jun 01, 2016 | Toro Garden
Tempstar Air Conditioner wont come on
Sounds like you need a new contactor in the condenser. The low voltage is grounded. Remove the low voltage (likely 2 wires) at the condenser and wire nut the wires leading inside. With an insulated screwdriver manually push in the contactor and be sure both compressor and fan run. Then replace fuse and turn power on to air handler with a call for cooling. Obviously the outdoor unit won't run because you unhooked the low voltage but if fuse doesn't trip then it's likely the contactor. Good Luck
Apr 10, 2017 | Heating & Cooling
When i press the cool button the air turns on for one or two minutes the shuts off
I Have a aircondition Tempstar PGAD36D1K, on the thermosta the target temperature is 78F but aircondition star working at 85F and stop at 82F.
We want to kwow how we can fix that. This is the second thermostat the we buy and we still hace the same problem.
Thanks
Jun 09, 2011 | Heating & Cooling
Trying to find ton rating for a Tempstar 9000 mod# CA903VKA2.
If this is a window or portable unit, you will not find the tonnage only the BTUS. My guess is 9,000 BTUS
3,000 less than a ton
Jun 17, 2010 | Heating & Cooling
Where can I BUY THE cords at.
I've never seen the ad for a weed thrasher but, as far as a replacement cord goes. You can buy a extension cord of the same size and install it. Just cut off the end. The wires within the cord need to be the same size or bigger, never smaller. Also it's important to replace a 3 wire cord with a 3 wire cord. You can use a 3 wire cord with a machine that came with a 2 wire cord, just cut off the green wire at the machine end. Your wire colors should be white, black, and green. Black and white are your power wires and green is your ground. Usually black and white are interchangeable but, on occasion switching them may make the unit run backwards so install them in their original position. Write down where they where hooked up and install your new cord in the same places.
Mar 23, 2009 | Weed Thrasher Replacement Cutters As Seen...
Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Sep 26, 2008 | Emerson Heating & Cooling
Condensing unit
Probably one of the wires going to the control board or contactor has been pulled off when this happened. If you feel comfortable trying to reconnect these comment me back and I will try to walk you through it. PLEASE REMEMBER THAT THE CONDENSER HAS HIGH VOLTAGE INSIDE OF IT.
Jun 27, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
