Question about John Deere Garden
Need to know how to install the rear wheel weights on a john deere 2305 tractor
4 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: John Deere LA175 lawn tractor front wheel bushings
Remove the tire and wheel from the spindle. Take a long punch or similar item and reach in the center of the wheel hub where the spindle goes. Locate the space in between the inner and outer bushing and tap the edge of the old bushing until it comes out. Now go in from the other side and do the same with the other bushing. This one will be a little easier to do since you don't have to hunt for the center space. Put the new bushings back in the same way just be sure you drive them in STRAIGHT
Posted on Sep 18, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
Solenoid 2305 john deere
When bolting it on, be sure good and clean. Its your ground for solenoid.
Jul 26, 2014 | John Deere Garden
John deer tractor 2305 will not start, will turn over
Every small engine needs three things to run. Compression, spark, and fuel. I would check in this order. Compression and spark testers are available at any local auto parts store. Once you have checked these let me know what you have found and we will continue diagnoses. Good luck!
Aug 10, 2013 | Garden
Change rear tire on john deere lawn tractor lt-150
i guess the wheels are stuck you will damage the wheels and axle trying to get them off just pop the beads and change it right on the mower
Apr 16, 2012 | John Deere Garden
Where can I buy the 30 amp altenator for the 2305?
They only offer a 20 amp or a 35 amp but the best place to buy either would be at your local John Deere dealer.
Oct 30, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
Garden Logo
237 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
