Question about Panasonic CW-1006FU Air Conditioner
My Ac wont turn on becauser the timer light is blinking Panasonic inverter R410A
Use the remote to retrieve error code,on the bottom of the remote you will see a CHECK bottom,use a pointed pin to press it for 5 seconds the display of the remote will change to two underscore, then scroll the arrow beside the time,r press until you hear beep sound, then jot down the error code..there's a error code you will see inside the panel of the indoor unit,for quitting press again for 5 seconds the Check bottom
Posted on Aug 31, 2010
  • guar73 Jan 29, 2011
    When the timer light starts flashing and you get an error code r41 i think. This means you have no gas left in the compressor unit. You most probably have a leak in your piping
  • vizuals4 vizuals4
    vizuals4 vizuals4 Nov 06, 2015
    I hv an error code 36. How do i rectify?
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Timer of my panasonic inverter ac is blinking n aircon is not getting on. how do i resolve it
Unplug the power cord or if you are unable to turn off power that way, use fuse box and leave power off for 20 minutes. This should enable the system to reset to default settings and you can then set system to your needs.
May 06, 2016 | Panasonic Heating & Cooling
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
O general split ac indoor timer light 5 time blinking .what problem
There's a redlight turned on in the inverter of my O General 1.5 ton AC. What might probably be the problem? Please guide.
Jun 02, 2015 | General Heating & Cooling
I have daikin split ac and it stops suddenly and blink the green light and after awile i turn it off then on and works again.. whats the problem ?
trying to get the panel to work. Its blinking and won't accept commands.
tried new batteries..still does'nt respond
Aug 29, 2009 | Cfm Daikin R410a Split System Air...
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Jun 03, 2008 | Heating & Cooling
Panasonic CW-1006FU Air Conditioner Logo
3,825 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
