Question about Sub-Zero Bottom Freezer Refrigerator
Subzero 550 stopped making ice. should lever be up or down
  • 122 Answers
Lever up is off down is on
Posted on Aug 22, 2010
Subzero 550 makes ice and then stops, can hear solinoid trying to fill but no ice.
water filter clogged, fill solonoid clgged, or inline screen clogged, check all that applies
Nov 27, 2012 | Refrigerators
How do you get an icemaker in a subzero 650 refrigerator to stop making ice when the bin is full?
There should be a metal bar that flips when it hits the ice at a certain level. It should stop automatically. There is a problem with the sensor.
Oct 08, 2012 | Sub-Zero 650 / O Bottom Freezer...
My subzero 550 ice maker is not making ice
My subzero model 550 is not making ice after I shut the water off for a plumbing repair. Now that I turned water back on my icemaker is not working.
Jan 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Water is not draining down the drain tube in the main compartment of the subzero 550 refrigerator
clean drain line . force hot water down the drain as the get algi and stuff in them . if problem happens again then use a drain heater kit ( subzero ahd one for this model ) this will prevent ice over .. **** hope this will help ..
Dec 23, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice keeps forming inside on the back panel of mysubzero model 550
If the ice is on the back panel especially a block of ice in the middle left part of your panel, then you have a sealed system problem. Check to make sure that your condensor coils above the refer are clean, and if it continues to have an ice block then you have to have a technician come out an do a major repair. This is not something you can do yourself, most subzeros have a 6 to 12 year sealed system warrantee that covers either all of the repair or just parts. This is an expensive repair if it is not warranteed, but when the refers cost 8000 to 10000 new it is usually well worth it. Most often it is the result of a slowly leaking evaporator, though most inexperienced technicians replace the compressor first, so make sure you use an experienced Sub-Zero technician. Good Luck, Appliance Specialits
Nov 12, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Air in line to Subzero icemaker
Are you sure there is still water available to the ice maker?
Having a little air in the line might make the water spit a bit but it should be quickly purged and function again.
Also, lift the stop lever on the ice maker inside the freezer compartment, then let it back down to cycle the ice maker and see if that re-initiates the ice making cycle. You'll know because there will be water in the ice tray. It may take a few minutes to cycle.
It's also possible that when the water was turned off and back on, some debris in the water line made its way to the water valve for the ice maker and plugged it. Some units have a screen that can be cleaned, but make sure the water is off to the fridge before disassembling this line and attempting to clean any debris.
If your fridge has a control board on the back of the unit, un plug the fridge for about two-three minutes and then plug it back in to reset the system.
If you did get it to work again, toss the first two to three sets of ice just in case there was dirt in the line.
Apr 27, 2009 | Hotpoint HSS25GFP Side by Side...
SubZero 550 Refrigerator Coils Freezing
defrost problem ... do you have frost or ice?
Aug 25, 2008 | Maytag MSD2758GEW
Freezer Drawer Stuck
Our 550 bottom freezer drawer froze shut earlier this week and the motor made an unusual sound, like it was working too hard. Two of us eventually were able to open the drawer to find that it had frozen shut due to a leak which filled the ice tray solid and then adhered to the actual door, freezing it shut. We emptied the fridge and freezer, turned the control dials down to 0, but neither the motor nor the light would go off. We finally killed the circuit breaker to get the appliance to shut down. It's cleaned and defrosted and we noticed that the gasket has torn in three places, two on the fridge door and one on the freezer door. The freezer door could be from our tugging, but the refrigerator door is normal wear and tear. We filled the tears with some kind of putty and when it is dry we will start everything up again. This is not the first problem of this nature we have experienced with our subzero 550, but it is the most dramatic. Each previous time we have called a repair man out and he has been unable to fix it.
Aug 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
355 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
