Question about Refrigerators
I have an Addi Arizona Model water dispenser and cooler. It has recently begun to freeze up to the point where you can't get any water out of either the room temp or cold side. I suspect a switch that isn't cycling the compressor, hence runnng continuosly and causing the freeze. Let me know your thoughts and where to possibly get parts to repair.
huuum
  • 750 Answers
SOURCE: Hamilton Beach 87330 water cooler
Hello mmmm,
Welcome,
how old is the unit?
And what did it cost you?
It has a bad thermostat.
Try unplugging it for 5 minutes and see if it resets.
If it runs continuously the compressor will soon burn out and die!
If not do not spend more than half of what it cost to repair it!
This is the rule of thumb.
You said ,The water cooler wont stop chilling the cold water. Normally, it would shut off once the chilled water has reaches a certain temperature, but now it runs continuously. any ideas how to fix??
Thank You for using our site for advice,
huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
  • 1214 Answers
SOURCE: Freezer is cool but not freezing or making ice - fridge not cold
If there is frost on the back wall of the freezer, then the compressor is running. Another (maybe) good thing is the fan is running.
The problem could be -
1) Bad defrost heater
2) Failed defrost sensor
3) Failed defrost timer or refrigerator controller board.
There are diagnostic tests to determine the problem, but require skill at using a multimeter and possibly reading a schematic/wiring diagram.
You can temporarily make the refrigerator run again for awhile by unplugging, opening the doors, and defrosting for 6-8 hours (store food in coolers.). Then plug it back in. Note, water may come out of the freezer as a result of defrosted ice.
Posted on Jan 15, 2009
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
bobicehouse
  • 1524 Answers
SOURCE: Whirlpool refrigerator dispensing cool (but not cold) water!
You are correct. Same as refrigerator temperature.
Posted on May 04, 2009
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
Posted on Jul 18, 2009
Addi water cooler manual, my cooler is broken, pls help thanks flor
There is no water coming out of the hot or cold Water Spinets I think the motor burned out
Oct 29, 2009 | Kitchen Appliances - Others
My addi cooler no longer cools the water the hot side is working fine is this a quick fix and/or is there an 800 # to call
you search for addi and you get other bastards who list under addi, but have no addi. I cant even find the company phone no. i think they are out of business. I have a similar problem and it is the thermostat that is broken. To check this, remove the two wires to the thermostat mounmted on the back condensor and connect them together temporarily and see if the cooler works. if it does, then replace the thermostat
Aug 03, 2009 | Hamilton Beach Water Cooler with Storage...
I cannot dispense water from the cold water/fan runs all the time
first of what temperature are you running is the refrigerator and also what is the ambient temp? whats happeneing is that the water resevour is freezing in the back of the refrigerator . So if the temperature is say 34 iit can actually be a lot colder in the regfriigerator than that due to temperature averaging. Thanks fpor using Fixya and Merry Christmas
Dec 23, 2008 | Hamilton Beach Water Cooler with Storage...
It is freezing up inside the cooler
Turn the screw on the back of the unit so that the water is not chilled to such an extreme cold
Jun 20, 2008 | Avanti Hot and Cold Water Cooler
Water won't dispense from side by side fridge
check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Jun 11, 2008 | Refrigerators
Cold water freeze
you have to lower the termostat because is freezing the the cold water duct that happens when is cold or winter
Jan 01, 2008 | Soleus MW-55
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
