Question about Hitachi Travelstar 5K100 HTS541080G9SA00 80GB 5400rpm 150MBps Serial ATA Serial ATA/150 I... (0A26924FT) Hard Drive
Hi where is the jumper to put the hard drive into slave position on a hitachi TRAVELSTAR HTS541080G9SA00 ? I cannot find it Many thanks best regards
  • 245 Answers
Hi
There are no jumpers to set on a SATA drive since they all use individual interfaces with the motherboard.
All you can do is connect the drive you want as master to the first SATA header,slave to the second,and then set the boot priority in BIOS.
They don't have jumper pins like the old days.
Post again if you have questions,and if this helps would you rate my post?
Bob
Posted on Aug 22, 2010
Hitachi Hard drive DK23EB not readable -please help
Have you put the hdd from the laptop into slave mode, its on the back of the hdd, there might be a "jumper" that you need to reposition, failing that only insert the 1 hdd from the laptop and make it the only hdd, it should have an operating system on to run as normal. You can see the <jumper> on the right of this picture, you will need to connect both teminals (slave) with a little plastic jumper.
Apr 03, 2014 | Hitachi TravelStar DK23EB Series DK23EB-40...
I am trying to acess the HTS541080G9SA00 hard drive as external USB drive. I can see the drive in the Device Manager but cannot see it in my computer. Please advise. thanks
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
hope this helps
Oct 17, 2011 | Hitachi Travelstar 5K100 HTS541080G9SA00...
I have a extra hitachi hdd 30 gb ..i want it to be a external hard drive.. i reformat it already and the hitachi hdd 30gb is now in the external enclosure.. the problem now is that my computer didnt...
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 18, 2011 | Hitachi TravelStar DK23EA Series DK23EA-30...
Which of Hitachi Hard discs could be a better replacement for model HTS541080G9SA00???
Just choose Hitachi Travelstar 320 GB, 5400 RPM, SATA , 2.5'' for convenience files storage.
Dec 19, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
I am replacing a Hitachi Travelstar 5K100 HTS541080G9SA00 80GB with a Western Digital 500GB SATA 3Gb/s Hard Drive 8MB 5400RPM 2.5IN Scorpio Blue. A tech told me to use a cloning software to switch the...
You would need to use a "usb" to hard drive cable. It looks like this: http://gizmodo.com/168149/brando-sataeide-to-usb-20-cable
Then, it is simply a matter of "cloning." The other alternative is to find a pc repair shop with a hard drive duplicator. It will copy much faster.
Please rate if you find this helpful.
Sep 20, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Replacing laptop HD
Spend the money and go with a 7200 rpm drive, 160, 320, or 250 gb hard drives are all under 100 bucks these days.
Oct 03, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Hitachi Travelstar HTS541010G9SA00
No the drive is not customized at all. It is a standard SATA Data and Power connector. However, if it was already mounted in a laptop chances are the laptop manufacturer may have put an adapter on the connector end to allow for tight right angle insertion into the laptop chassis which isn't possible with the stock connectors without leaving the drive loose in it's slot.
If this is the case grabbing the connector and pulling straight away from the drive should pop it loose and reveal the stock SATA connectors under it.
If you're having troubles removing this peice, comment back with the make and model# of the laptop it came out of and I'll see if I can pull a diagram for you.
Chris
Jun 04, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Unusable drive with bad sectors in drives service area
I would temporarily attach it directly to your laptop and go into recovery console and do a chkdsk /r on that drive
see if that helps, if not then there are things you can do.
post back for more info
May 17, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
What is the jumper setting to make this a slave
If it's USB you shouldn't have to mess with the jumper settings but here is a site that appears to have them for TravelStar: http://www.ontrack.com/jumperviewer/ If the drive is not showing up in My Computer make sure there is a drive letter available for it to use. You can right click on the My Computer icon, select Manage and then go to Disk Management and see if the drive shows up there and then assign it to a different letter.
Mar 30, 2007 | Hitachi Travelstar 80GN 60 GB Hard Drive
Computers & Internet Logo
529 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
