Hi
Thanks for using FixYa. Error code
F/H means no water was detected entering machine or
Pressure switch trip not detected. If after 30 seconds the control
does not detect water entering machine and then valves will be turned off and
the error code will be displayed. It can also happen if the control has turned
the water valves on and after 8 minutes the flow meter has detected 10.5
gallons of water passing through it, but has not detected the pressure switch
trip, the valves will be turned off and the error code will flash. You’ll need
to Press PAUSE/CANCEL twice to clear
the display and then check:
• If
there is no water in the unit:
• Make
sure that both valves at the water source(s) are turned on all the way.
• Check
for plugged or kinked inlet hoses or plugged screens in the inlet valves
Verify inlet valve operation
• If
there is water in the unit:
Verify Drain pump operation
Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure
switch
Verify there is not a siphon problem
Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow
Meter and Central Control Unit (CCU)
• Check
all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
• Verify CCU operation
Please do
rate the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
