Question about Dell Inspiron 8200 Latitude C840 Laptop Keyboard03J247 CD-ROM Drive
Keyboard responds time
I've tried to adjust the settings in the control panel but still nothing wants to work.
  • 487 Answers
I am staring to think that your drivers are corrupted.
Try Dell first for downloads of drivers for this computer.
If this does not work come back to me and tell me which OS you are running.
I check normally every day to see the answers
Posted on May 07, 2008
Keyboard slow to respond only in gmail
By default, the keyboard comes with appropriate adjustment, but in case of any problems can check the configuration of the keyboard, for this you'll control panel, (click) keyboard> keyboard properties now on you can check the speed,
Aug 01, 2014 | Acer Aspire V5
When my tv is powered on, it displays the device menu and continues scrolling through it, but will do NOTHING else. I've tried to reset, and nothing. The tv will not respond to the remote at all.
A suggestion here: If possible to remove front speaker grill and inspection plate that should be behind it---locate the bundle of wires that comes down from front keyboard with the buttons and follow it to the right and down---should be one or two plugs in-line--------disconnect them with the set off and power set back up with remote.
If the problem is gone you have a bad micro-switch on the front of the set------buttons on the keyboard there have priority over the remote---hence you cannot if the problem is there stop it with the remote or do anything for that matter.
Let me know what happens and I will suggest options.
May 31, 2012 | Televison & Video
My dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Nov 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
When i want to type something it doesnt respond but the mouse works just fine..
Take the keyboard off. Shut your PC off. Plug back the keyboard well and restart your PC. Test your keyboard. Does it respond? If it doesn't, left click your Setting, Control Panel, and the Add Hardware wizard. Troubleshoot and reinstall the keyboard. Back to the Control Panel, left click the Systems, Hardware, and the Device Manager. Then left click, the Keyboard,
right click to open and see the properties and status.
If it says it is working properly, then try changing your
keyboard and see the result.
Nov 25, 2009 | Computers & Internet
Keyboard not responding or responding slowly to key strokes
do the batteries need changed
if so make sure you shutdown first
or check settings for keyboard in control panel
Jan 08, 2009 | Dell R6053 Keyboard/Multimedia Control...
Spilled water on my toshiba satellite notebook
try : start-control panel -mouse and keyboard, if nothing weird appear,try to reinstall the driver for the keyboard,you'll find it here:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1311513&rpn=PSMA0U&modelFilter=M105-S3002&selCategory=3&selFamily=1073768663&selModel=1311513%7CPSMA0U
If it doesn't work you will have to change the keyboard and hopfully, there is nothing wrong with the motherboard
Jan 01, 2009 | Joy Toshiba M105 S3002 Notebook
To adjust the key repeat rate
  1. Open shortcutcold.gifKeyboard in Control Panel.
  2. On the Speed tab, make changes as follows:
    • To adjust the amount of time that elapses before characters repeat when you hold down a key, drag the Repeat delay slider.
    • To adjust how quickly characters repeat when you hold down a key, drag the Repeat rate slider.
note.gif Note
  • To open Keyboard, click Start, click Control Panel, click Printers and Other Hardware, and then click Keyboard.
Good luck and please rate me
May 02, 2008 | Computers & Internet
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Computers & Internet Logo
Alun Cox
