Question about Karcher 1750 psi Electric Pressure Washer
When i operate the switch on my karcher pressure washer the power wash does not operate.
  • 661 Answers
But water comes out the end right? just under hose pressure only I bet. I have one of these units and every time I think it has gone bad I manage to find the problem. This unit not only has the switch on the front that needs to be on but it also has a safety switch on the plug where it plugs into a wall or extension cord. The last time I thought mine had gone bad it had actually blown the fuse. the unit was plugged into an outside outlet via extension cord. It just so happens that that is an GFCI outlet. I think the wife got water on the extension cord and that caused it to blow. So check:
The power switch on the front The safety switch on the cord, The outlet it is plugged into
Usually, for us, it is the button on the cord when it is plugged into an extension cord it always gets the test button bumped which shuts it down.
Posted on Aug 22, 2010
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
Karcher 380 works fine until I turn it off. it will then not work for say half an hour
over pressure switch stuck, dismntle switch and clean or replace ( located between on/off switch and pump head
Feb 22, 2014 | Karcher Garden
Karcher 1600 pressure washer will not get power. It was working then stopped getting power. It is not that old.
ok im a technician... cheak d power swtich. i think most of karcher power knob switch they got a error problem.
May 30, 2011 | Karcher K2.26 Electric Power Washer
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
How do you reset a karcher pressure washer
The Knob is broken off of the Plastic Shaft..to the switch assembly.
A new switch assembly is available direct from Karcher.
May 24, 2010 | Karcher K2.26 Electric Power Washer
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
There is no power when you use the sprayer Karcher K2.89
Depends on the model, but it is probably the pump, Most Karchers do not use expensive pumps. Also, if the end of your hose is off, you won't get much pressure either as it takes a restriction in the end of the hose to increase the pressure. I have commercial pressure washing business & occasionally have an hose end come off, pump problem or high pressure switch problem, but all this stuff can be fixed. Hope this helps you, Rick
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 1750 psi Electric Pressure Washer Logo
311 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
