Question about Nokia 6233 Cellular Phone
Radio problem i have got a problem with its radio its does not work even it doesn't swithes on nor its tells to connect an enhancement it remains as it was
  • Himanshu Bansal
    Himanshu Bansal May 09, 2008
    this answer is in appropriate because because i have mentioned that it
    even doesn't shows "Connect an enhancement" well when i connect even
    then it remains the same
    President:
  • 1,944 Answers
Did you connect the wired headset before you activated the radio?
Posted on May 04, 2008
I have been told the problem I have is with the Radio Wiring Relay, The drive side window and radio doesn't work I checked the fuses all good, The passanger window very slow up or down. Where do I...
Sorry but you have been led a wrong one by someone who obviously doesnt know anything ,no doubt a bar room mechanic who the more he drinks the more he knows???? the circuits are completely different and are not connected .Ask a local mechanic to have a look for you ,window slow is a problem with track its pinching the glass making the motor work overtime and the radio ?? would need to check it out myself to pass any comments but a radio wiring relay¿?¿? this is a new one to tell all the mechanics i know thats for sure
Sep 14, 2011 | 1995 Chevrolet Camaro
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
My nokia n 73 phone is howing enhancement symbol on the right corner of the screen even if no enhancement is connected and when i make or receive calls, i am not able to hear the other persons voice and...
try to clean the headset interface at the bottom,might the socket is corruded and lead inoto shortage...
if that symbol never removes.you can never hear incoming calls or even the person calling might not here you...
if doesn't work,bring it to a mobile srvice shop near you. might a hardware (board) problem.
hope it helps....
Jun 04, 2011 | Nokia N73 Cellular Phone
My nokia radio off
If you turn on your radio and it does not come on as you say, there are different sides to the problem.
1. If when you turn it on, it does not come on, and probably tells you that 'enhancement is not supported', then the problem is from the enhancement (ear piece). Get another enhancement and try again. If you have done that and it still was not helpful, or the problem was not even from the enhancement, then proceed.
2. If when you turn it on, it shows a station or frequency number on the screen, but you dont hear anything, then the ear phone of your enhancement is faulty. To confirm that the problem is from the ear phone, select
options> loudspeaker.
If you hear the sound, it confirms that the ear phone is bad.
You can then use your old enhancement on loudspeaker or get another enhancement.
Hope that helped?
Success.
May 10, 2011 | Nokia Classic 2700 Cell Phone
HONDA ODYSSEY 1995: WHERE IS RADIATIOR FAN SWITH LOCATED ? TROUBLE : FAN NEVER STOP EVEN WITH MOTOR OFF.\r\nSO, BATTERY GET DRAINED. THANKS, Charles from Québec, Canada
the fan is supposed to remain on until the engine temp falls to a certain temp. your problem is with the monitoring circuitry that is supposed to tell the fan to shut off. same circuitry leaves the fan off on start up until the engine reaches a certain temp.
Dec 13, 2010 | 1995 Honda Odyssey
WIRELESS SWITH RADIO ON OFF IS NOT WIRKING
Does your computer have an ON/OFF button (or slider) for the wireless, and a separate ON/OFF button (or slider) for BlueTooth?
Try each of the 4 settings:
* OFF/OFF
* OFF/ON
* ON/OFF
* ON/ON
Click Start
Click Control Panel
Click Network Connections
Click with the SECOND (usually the RIGHT) mouse-button on the wireless-adapter.
Click ENABLE.
May 14, 2010 | Dell Latitude E5500 Laptop
Nokia 5200 - radio not working - connect an enhancement error
I Think there is some problem in Radio settings, so just make sure to reset mobile settings
Jun 17, 2009 | Nokia 5200 Cellular Phone
M nokia 2626 phone radio is not working even i connect my headset
Hi Friend,
Wither did u tried with any other handsfree to our mobile.
The problem may be in the handsfree or in the handsfree slot
check it by changing the other handsfree
Regards,
Ayyasam
May 29, 2009 | Nokia 2626 Mobile Phone
Laptop cannot find access of newly installed dynex G Router
Follow the tip I prepared
Find the radio swith on your Think pad and activate it (model?)
try FN + F5 to activate the radio config.
Be sure radio is ON.
Before every radio test check your internet configuration connecting to router with LAN cable and browse.
Jan 08, 2009 | Dynex Enhanced-G Wireless Broadband Router
Radio nokia
All know that Radio can be used only with ANTENNA......
In Mobile, that antenna feature is integrated with the enhancement,i.e, headset compatible with 5200 ......
So connect the headset before turning on the radio....
Hope this helps......
Oct 03, 2008 | Nokia 5200 Cellular Phone
Nokia 6233 Cellular Phone Logo
80 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
