Question about Black & Decker SZ360 Cordless Power Scissors
I have an Allegheny 24 volts combo tool set that is missing a rechargeable battery and charger. Where can I get the battery and charger? Thanks Sal
    Sergeant:
    Champion:
  • 389 Answers
You can order 1 from black & decker ,from ther website or by phone.or in some cities they have stores.or try battery depot.
Posted on Sep 03, 2010
What voltage should come out of a 24 v 3 pin charger? single 12 v pin with two ground pins?
It depends on how it and the wheelchair are wired and how the voltage is derived.
Presumably the 24 volt wheelchair requirement is provided by two 12 volt batteries connected in series and these could be recharged in series by a 24 volt charger and a pair of wires or by a 12 volt charger providing a 12 - 0 - 12 using three wires where one 12 is a positive in relation to the 0 and the other is a negative in relation to the zero making a potential difference of 24 volts.
There could conceivably be circuitry within the wheelchair that requires only 12 volts for recharging and causes the two batteries to be charged separately, though while this method could be desirable and offer some benefits it would be considered unnecessarily expensive and complicated for most commercial purposes.
As usual you really need to know what is supposed to happen or is designed to happen before fault-finding can begin. One of the wires could be a safety ground wire but most likely it is used to provide some sort of feedback to the charger from, perhaps, a thermal switch close to the batteries so charging will cease if too much heat is generated.
Nov 02, 2015 | Pride Jazzy 1113 ATS Indoor Power...
My 18 volt Ryobi battery shows charged in charger (Green Light) But will not work in any of the power tools. I have three other Batteries that do work. Bought at Home depot on july 24 2011 Ryobi Two 18V...
Some of batteries drain very quickly. Depends on how they are used.
Feel free to check Your Local battery Manufacturer for best prices for all different batteries. You name it and they have it or they can custom make a battery for you.
Thanks
Oct 09, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I have a B&D 24 volt drill/ flashlight/ skill saw combo, reciently either the battery or the charger is bad, I put the battery in the charger an the light on the charger flashes (even when unplugged)...
If the charger is lighting up its probably the battery. Rechargable batteries have a lifespan governed by the number of charges.
The only sure way of knowing is to have another battery or charger that you know does work.
if it is the battery its normally cheaper to buy another complete drill.
Sep 13, 2011 | Black & Decker Black And Decker FS24C...
Looking for a 24 volt charging stand. P # CT-120-c. for a Allegheny 4 pc. combo kit. cordless drill/saw/sander/light.
If you can't get one directly from mftr, try a Batteries Plus store, they have access to thousands of applications
Jan 06, 2011 | Garden
I need a replacement 24 v battery charger for my Allegheny power tool set Model CT120-C. Where can I find one?
Call Alltrade customer service representatives at 1.800.423.3598. they own Allegheny. have model number ready
Nov 22, 2010 | Black & Decker Hand Tools
Where can I find a replacement charger for the allegheny ciw114 impact wrench?
If the battery is not damaged or totally dead, you can attempt to charge it with any
24-Volt DC charger. The charging voltage rises to about 28 Volts when nothing is
connected to the charger. You must first connect (with jumper leads) the positive
charger output to the positive battery terminal. Use a test meter to determine the
polarity of the battery. Also test the charger output to determine the polarity. Be
sure to connect positive to positive and negative to negative. Do this before turning
on the power to the charger. If the battery is a "smart" battery; that is with built-in
electronic control circuit, the ordinary charger may not work. Normally, a battery
will accept a charge until it is nearly completely charged and then the battery
voltage will slowly "buck" the charging voltage. When the battery voltage and the
charging voltage are equal, no more charging current will flow. Amperes, that is
coulombs of current, charge the battery; when the battery is at (approximately) 24
volts and the charger is putting out 24 volts, NO current flows. The battery is then
fully charged.
Dec 28, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
Charging the battery is useless every time!
I HAVE A ALLEGHENY 24 VOLT IMPACT WRENCH THE CHARGING STAND IS BAD HOW CAN I GET ANOTHER ONE OR CAN YOU TELL ME HOW TO CHARG THE BATTERY?
Nov 09, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
Black & Decker SZ360 Cordless Power Scissors Logo
484 people viewed this question
Top Black & Decker Hand Tools Experts
Don Numinen
Don Numinen
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
