Question about Star Logic 17" LCD Monitor
I do have a question, i was using old starlogic monitor (actually i have 2 of them, for now, 1st one is old, the second one is 'twin' ) i bought a pc emachine couple of months ago in april. any way. the old one worked fine up to couple of days ago. now, heres the question, it works up to windows log on window then i get a error message saying 'out of range' what is that?
  • 2,973 Answers
What I have understood is that the resolution of the Windows is way too high for the monitor. Remedy. reboot in safe mode and when booted, right click on the desktop and select Properties->Settings. It will show you the display settings including the resolution. Reduce the resolution and keep the highest that the monitor can take. You may have to reboot a number of times. All the best.
Posted on Aug 22, 2010
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
When I first turn on my computer, my Starlogic
An internal component failure inside the monitor, replace the monitor.
May 12, 2010 | Computers & Internet
For my mac g4 first generation, i bought a Ati radeon 7000 PCI. the goal was to stop using my original graphics card and use the ATI radeon 7000 for my main and only screen but when i start up with my...
hello...the way is try to open the Bios Settings then disable the on board video then set primary AGP/PCIE slot Video Card to run then try again to install the video card driver but 1st you need uninstall the old driver..thanks and Good Luck..have a nice day..^_^
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
How to covert Starlogic M17ANA into tv screen.
yes a dvi to VGA converter is available they are available online and over the counter at an electronics or computer store
Feb 05, 2009 | Star Logic 17" LCD Monitor
Black flickering line vertickally through monitor screen
It could be either of these:
You're monitor is dying and you need a replacement (Starlogic brand is notorious for dying early and giving poor performance)
You're graphics card is going out. If you have an extra monitor laying around, take out the Starlogic one and plug in the other to see if the same results occur, if not, it's the Starlogic monitor, if the problem still persists, you need a new graphics card or need to update your current drivers.
Dec 15, 2008 | Star Logic (11004998) (Black) 15 inch LCD...
Starlogic monitor under warranty
take it back to the local store where you bought it. or
check their website to know where to take it to
Mar 24, 2008 | Star Logic 17" LCD Monitor
Problems with monitor
Are sure you plug into the right socket jack.
Try plugging different socket and listen.
Jan 19, 2008 | Star Logic 17" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Starlogic monitor
I been working on lcds for some time and what I find is caps in power supply dry out over time. If you can open case and see if cap pop out at the top of it. thats your problem...cybrg0000
Oct 21, 2007 | CTX S762A 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
55 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
