Question about Jenn-Air JCD2389G Side by Side Refrigerator
We have a Jemm-air model JCD2295HES and it is not cooling or freezing. It runs and does have some cooling ability but even when turned up all the way will not reach desired temps.I beleive the product is around a year old but the company we purchaced it from has gone out of business. Any suggestions?
  • 10,515 Answers
You could follow a simple troubleshooting chart :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 22, 2010
Why does Our refrigerator keeps freezing everything? Even the food in the drawers are frozen. Why is that?
Check the cold control thermostat setting maybe you set it to max. put both controls on middle of whatever numbers you have on them and if its already on middle or at minimum setting still it freezing everything you need to replace to Cold Controller Thermostat
Aug 23, 2014 | Jenn-Air JCD2295HES Side by Side...
I have a Jenn-Air side by side refrigerator. JRSD209T. Water fills up the ice shute and runs into the floor. What stays in the freezer freezes in the chute. What do I need to change to fix this problem
From your description I'll gather you're not getting ice cubes either and need to replace the ice maker
Part # D7824706Q on the diagram labeled "Lights and Ice maker" it's item 1
This is from Sears so you can order and have it delivered to the house
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2295HES/1266/0165000?pathTaken=
Jan 01, 2011 | Jenn-Air JCD2295HES Side by Side...
Refrigerator compartment too warm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Jenn-Air JCD2295HES Side by Side...
The freezer stopped freezing-the ice is melting and the cooling section is not getting cold.It has power lights are on but cannot adjust the temp.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Oct 16, 2010 | Jenn-Air JCD2295HES Side by Side...
Freezer is not cooling at top - ice melted -not cooling on top of refrigerator - bottom of refrigerator is frozen
Check the back wall of the freezer for a ice buildup.(failure to defrost)
Check the freezer fan motor. Is it running?
Feb 12, 2010 | Jenn-Air JCD2295HES Side by Side...
Frigidaire upright model #MFU20F3GW8- Food not freezing
Check and clean the air cooled condenser for dust and dirt. Check and make sure the fan in back, on the bottom behind a removable panel, is operating. After cleaning the condenser replace the panel.
Also you stated there is no frost anywhere. Did you check the back wall of the freezer for frost buildup. If not check it and if there is frost there your defrost system is not working and the frost has stopped air circulation.
Jun 14, 2008 | Freezers
Amana heat/air conditioning pump
You are going to have to increase the amount of heat absorbed by the evaporator coil on the indoor section of your system. First change the filter. Second turn the power off to the outdoor section and leave the indoor fan running until all the ice on the evaporator coil has thawed this could take a few hours. Third you need to verify that you are getting adequate airflow across the indoor evaporator coil and the outdoor condenser coil both fans should be spinning at full speed and airflow should be unobstructed by dirty coil fins or debris Hopefully after you've done this you will have cold air blowing inside and the larger of the two lines entering the unit outside will be cool to the touch but not frozen or even frosted regardless of run time and the small one should be the slightly warm but not hot. If the larger line continues to freeze then it could indicate a number of problems but essentially your condensers cooling capacity is outrunning your evaporator coils ability to absorb heat from air stream circulating in your home.Hope it works out for you GL!
Jun 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Freezer not freezing and fridge not cooling, motor clicking and fan working
not enough data on your problem what is the unit doing and check your spelling did the tech put on a relay? if so which one?
May 07, 2008 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JCD2389GEB side by side
the clicking noise is the motor overload. have a service tech check for a freon leak.
Sep 24, 2007 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
22 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
