Question about Apple iPhone Smartphone
Jail broken iPhone can't make calls
I have an iphone jail broken using ziphone3.0. I can detect my network, all the phone functions works even though sending and receiving text messages. I can receive calls. But however I cannot make calls. Once I click on CALL, it will immediately show Calls Ended, Calls Failed. Even thought I click CALL AGAIN, it is still the same. Any idea how to fix this? Please advice. Thanks.`1`12weeeeeeeeeeee1
  • 3 more comments
  • pcyeoh1976 May 04, 2008
    I am currently using version 1.1.4. I can make call for several first few times after i jail break my iphone. But eventually it will fail to call anymore. CALL ENDED and CALL FAILED once I dial a call.
    Please advice.
  • Anonymous May 05, 2008
    I had my phone jailbroken at the Makers Fair today and have the same outgoing call problem. How do I know what version of ziphone was used? Is BSD Subsystem 2.0 a "trusted" source. It says it is not. Did anyone have any success with using the patch.
    I am also on v1.1.4 and just had my phone jailbroken. I've had two problems so far: 1) call was fine for ~15 minutes then I couldn't hear the person. I checked to make sure the call did not get dropped. The timer was still going. I finally hung up myself.
    2) I tried calling back w/ same unsuccess as the other poster.
    When I finally was able to get through, the person I was speaking to said they could hear me. The MUTE button was not on.
  • Anonymous Jun 05, 2008
    same problem cant make call
  • Anonymous Mar 29, 2014
    Cannot get the cloud on my iphone..when I sign in there is a tab to click that says resend verificaton email. I never receive the email, have checked the junk or spam file, never arrives. so many pics on my phone I need to get them in the cloud...Quick! Thanks
I had something similar where my iphone just freezes and goes back to home 3 seconds after i go to the phone part of the iphone. I just went to settings>RiP Dev (something I downloaded after jailbreaking)>RiP Dev Products > Kate and there Look for a checked application called facelift. I unchecked it and my calling worked again. It was cause Facelift is not compadable with Winter Board (another app dled from installer) If this doesnt solve the problem then... sorry :x
Posted on Aug 25, 2008
Check your Settings > Phone > Show my Caller ID > it should be ON
kishorevenigalla@yahoo.com
Posted on May 29, 2008
Long long procedures man...
Heres just a few second procedure.Open up Cydia, in the search, type, "downgrade baseband". It'll give 3 options, 2 having fuzzyband in the text and one having ultrasnow, I REMEMBER, in the text. Simply click the ultrasnow, let it install. Your phone will reboot and you'll be able to make n receive calls... :) CHEERS.
Posted on Oct 19, 2011
    Problem Solver:
  • 17 Answers
You first install "bsd subsystem" found in installer. This could take a few minutes. Then, u install any patch that fixes dial crashes which is also found in installer. Some are version dependent so, choose one that corresponds with your version. e.g for a version 1.1.2, you could use 'appsupport patch (1.1.2)'
Posted on May 04, 2008
Restore Cell Signal
You will need these files/program:
1. Ziphone 3.0 program
2. Ziphone Firmware Files 1.1.2, AND 1.1.4. To get these files open Ziphone 3.0 then Click Help and Support, then middle box on top of page Web Links Firmware Files 1.1.2 and 1.1.4 (to make it easier to find I always save everything to the desktop)
3. Kiphone http://www.iclarified.com/entry/comments.php?page=1&enid=1536#commentsanchor
Not sure if all these steps are needed for success, I am just putting it all down becuase this is exactly what I did to get my cell signal back.
First, I uninstalled itunes 7.7.
Then I downloaded and installed itunes 7.5. At this point you will have to rename your itunes libray folder. Instructions are here: http://www.iclarified.com/entry/index.php?enid=1504
Next I downgraded the iphone to 1.1.2 using the link above.
Downgrading steps:
Connect phone to computer
Open Ziphone 3.0
Click on Prepare for Upgrade (this will put iphone into DFU mode)
Now you have to restore using itunes 7.5 (which will open up as soon as the iphone goes into DFU mode.)
In itunes hold down SHIFT key (FOR WINDOWS) while pressing RESTORE. This will allow you to browse for the firmware file 1.1.2 you previously downloaded. Click on the 1.1.2 restore file and hit OPEN. This will begin the restoring process.
You will probably get an error code noting the restore wasn't successful. Ignore this unless the error code number is in the 1600's.
After this I tried to jailbreak my iphone using Ziphone 3.0 but wasn't successful so I:
Repeated the restore process but his time restoring to 1.1.4. Got the same error saying that restore wasn't successful, which I ignored.
Then I closed itunes, went into Ziphone 3.0 (iphone still connected to computer) and clicked on Do it all!
Jailbreak worked fine except I still had no cell signal.
To fix this I went to:
Iclarified, (the BEST iphone website *******!!) Got Kiphone patch (see Number 3 above) installed it and got my cell service back.
Posted on Jul 17, 2008
    Problem Solver:
  • 5 Answers
Mms iphone 4 straight talk
shouldn't have jail broken it.
Jan 13, 2014 | Apple iPhone Smartphone
Download usb driver
To the best of my knowledge, there is no Authorized USB driver available for any iPhone. You may have seen an app available for an iPhone that has been jail broken. I have no experience with this, but I would recommend that you not pursue this. I have seen some phones jail broken by inexperienced people, and they were a mess. Good luck!
Sep 02, 2013 | Apple iPhone 3GS Black (16 GB)
I have an apple iphone locked to vodafone uk 5.1
Hi visit Mobileunlocksolutions.com to unlock iphone from Uk Vodafone network .Here they help you unlock your iphone using remote unlocking method with out jail breaking it .
Oct 19, 2012 | Apple iPhone Cell Phones
If i had my iphone modified (cyndia and installous), can i still upgrade my phone's software?
You can have it jail broken to Cydia of installous. But once Apple sends out another OS update and you update your phone, your phone will reset and you'd lose your jailbreak. you can jail break it again. but it would be harder to find a jail break made for the newer OS that apple had sent out.
Mar 08, 2011 | Eforcity Apple iPhone 3GS 16GB / 32GB...
Forgot my pass word
Hello , i had the same problem but i reset my password using www.unlock-iphone.org and i allso unlocked my iphone to use it on any network worldwide
Sep 28, 2009 | Apple iPhone 3G
Unlocked iphone
Just to give you a run down. When they said it was jail breaked or jail broken this means they ( the place you got it from ) have voided the warranty of the phone and broken the terms and conditions of the contract with apple and have unlocked it to any cellular network ie before you tried to upgrade it on itunes it would of worked with any network ie T Mobile etc
Because it was jail broken by the person at the store you got it from and you tried to update it over itunes , itunes and the firmware update detected this and has consequently locked the iphone so you cant do anything with it unless you apply the latest jail break to it or you go back to the shop and get a refund and buy from somewhere reputable ie an apple store or a cell phone place that is big.
I would suggest getting a refund and getting a normal one as jail breaked phones will always have the issue where everytime itunes releases an update it will re lock it if you try to update it through itunes which is a pain and the amount of stuff you have to do to re apply or get it re unlocked is a nightmare.
Easier to get one that is not unlocked and that way you can upgrade it with piece of mind and know it will update with out any issues.
Apr 09, 2009 | Apple iPhone Smartphone
Iphone 3g and 2007 toyota prius hands free
Both my 3GS and iPhone 4 connect to my aftermarket bluetooth headset in my car. The phones can then play music wirelessly into my stereo or be used for hands free calls.
Hope this helps, www.PuterCare.com
Jan 30, 2009 | Apple iPhone 3G
Intermittently my iPhone does not ring and incoming calls get forwarded.
Through the iPhone to dustbin and buy a normal phone. It works better than this iphone. This happens to a lot of people.
Jul 14, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
6,695 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
