Question about SNK Magnavox 19MF338B/27 19 in. LCD TV
I have a Magnavox 19MF337B, and it powers on and off a few times before staying on. After it powers on, I just get a white screen, and nothing else works. remote does nothing, and buttons on top do nothing. No sound either. I have tried hooking up to TV cable, and Monitor cable, neither which work... Debating after reading some other posts, if it is even worth fixing. Anything for a neophyte to try as far as a fix?
Don't buy anything from Magnavox or Phillips period. They won't take responsibility for their products and have no ideas what customer service means.
Posted on Aug 22, 2013
  • SNK Master
  • 1,212 Answers
In some cases these TVs were to be returned for exchange. As costs were excessive. If this TV is out of warranty and you have no place to go with this TV, you might just have a hobbiest open the darn thing up. I would say you have a bad capacitor or two in the power supply. This is at its easiest repair. If not you may have a bad LCD panel and that is not worth replacing! Hope I could give a something to work with. Thanks for asking!
Posted on Aug 22, 2010
  • Dawn Shrader Aug 22, 2013
    I will never buy Magnavox again. When my father called Target, they were rude and told him to call Magnavox. When he did, they blamed the issue on him. We only found out about the faulty components by searching on line. Neither company has no idea of what customer service is and can bite me.
4 Suggested Answers
  • 8457 Answers
SOURCE: TV will not power on
Yes,power supply board have dead capacitors leakage problems.These capacitors useally bulge up or burst open.U know how to solders?Look in the power supply board rerplaced these capacitors will solved the power problem.Or tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Mar 11, 2010
  • 736 Answers
SOURCE: My magnavox 42mf438b lcd tv will be fine for about
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Posted on Apr 10, 2010
vindicatedne
SOURCE: Magnavox 19MF338B/F7 TV fine yesterday, today no picture
A capacitor needs replacing, I fixed one I found in someones trash that had the same problem, A 330 microfarad capacitor (uf) rated at 16v (the damamaged cap just had a bubble shaped foil top that indicated it went bad. replaced it with another cap (high voltage rated for tv replacement cap) cost 1.99 and it all works Great!
Posted on Sep 07, 2013
Magnavox 19mf337b/27 will turn off and back on with loud noise through the speakers until it warms up. approx 30 to 40 min. What is the part causing this common problem?
Check the 2200uF capacitors for bulging. You can get the schematic here to really toybleshoot: http://www.electronica-pt.com/index.php/component/option,com_remository/Itemid,34/func,download/id,15048/chk,6022df47696641c1c064cb27f2bd7d11/no_html,1/
May 20, 2010 | SNK Magnavox 19MF338B/27 19 in. LCD TV
Magnavox 19mf337b/27b flat panel tv doesn't boot up
I had the same problem but was too cheap to replace the scaler board on a television which was not worth the cost. That board has 3 1000uf 10V aluminum electrolytic capacitors which had swelled tops and indications that they may have vented. Since they were installed using through-hole technology, they were easy to change with 1000uf 16V capacitors. (caps can not be more than 16mm tall). The set has worked fine for months. Cost of repair was 72 cents
Nov 13, 2009 | Televison & Video
Magnavox 20MT4405/17 Error and remote control problem
what you describe sounds like you have a short inside the safe bet is take it to a repair shop.
Oct 05, 2009 | Philips Magnavox 20MS233S 20" TV
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox 19mf337b 5 months various problems power off, ghosting, alarm noise
I am currently working on this model set and have discovered the same type of problems. Fix: 4 capacitors in the power supply section on the main board were defective (bulging out). Common problem with counterfeit parts that originate in China. See http://www.badcaps.net for details.
Oct 28, 2008 | Televison & Video
Vertical height adjustment on Magnavox 19 inch LCD HDTV
try to adjust at the vertical section.hope this will help
Feb 01, 2008 | Philips 19MF337B/27 19 in. LCD Television
Magnavox 19mf337b lcd tv
If the cost of repair is 50% or more of the price you purchase the TV at, your better off buying a new TV.
Nov 27, 2007 | Televison & Video
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
SNK Magnavox 19MF338B/27 19 in. LCD TV Logo
555 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
