Question about Ingersoll Rand Type 30 Electric Driven Two Stage Horizontal Air Compressor 120 Gallon Fully Packaged Ir 2545E10VFP
Hi, I have an old IR Type 30, two-stage compressor, model #: V242 N3. The current motor is 3hp, 1 ph,1740 rpm and may need to be replaced. Is it safe to use a full-speed, i.e., 3450 rpm motor on this unit? Additionally, I would really like to find a manual for this compressor. Do you know where they might be available? Thank you, Bob Sieger
    Champion:
  • 205 Answers
No you need to use a compressor duty motor same rpm using a higher rpm motor will shorten the life of the motor if you have 3 phase power even better single phase motors aren't as efficient and run much hotter and dont last very long on air compressors
Posted on Aug 23, 2010
Testimonial: "Thank you for your reply. It reaffirmed what I already thought, but I needed to be certain."
  • 183 Answers
Most "real" air compressors run quite slow and you should stay in that rpm range. If you wanted just a little more out of it you could bump the horse power up a bit and install a larger pulley on the electric motor.
Posted on Aug 31, 2010
I have an old IR 30 T that needs repair where do I find a manual for this
You may find your parts manual for your compressor here http://www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Just scroll down the page, the manual for an IR 30 is there, also on that website, you may find the problem to your compressor
Sep 29, 2012 | Ingersoll Rand - Rand Type - 30...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
I need to know what size breaker and what size electric cable should be used in the installation of this Ingersoll Rand SS3L3 3hp motor. I've ordered the compressor but it is supposed to take awhile before...
I am assuming that you will be hooking the air compressor to a 240 volt line...
That motor will draw about 18 amps...... so a 20 amp line will be too close to that draw....
so you will be looking at a 30 amp line...
For that you will need to run a 10gauge three wire with ground on a 30 amp two pole breaker...
that will serve you for up to about 100 feet of wire... if you are running the wire farther then that you will need to up size the wire to 8 gauge so that the motor can draw enough to get started...
heatman101
Jan 11, 2011 | Ingersoll Rand Single Stage Electric...
Motor takes high current and trips on over load
Maybe your are in low voltage thats why amphere is high.
May 11, 2010 | Ingersoll Rand Type 30 Fully Packaged Ir...
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
Motor pulley for an old Ingersoll Rand type 30 compressor
Here is a link to Ingersoll-Rand (compressed air division) where you can find a local distributor. I think a call to a parts tech might provide the original motor sheave outside diameter and belt size (I'm suspecting "A" or "B" size).
http://www.ingersollrandproducts.com/contact/air/index.aspx
With that info, here is a link to a good industrial source for your new motor sheave (McMaster-Carr):
http://www.mcmaster.com/#v-belt-sheaves/=3fwz7b
Their prices aren't so bad.
You may also have a local industrial sales in your area.
I hope this helps you... Nice compressor!
Sep 01, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Need help with parts for air compressor.
Hi ,Crazy horse. information perfect . with a14.5 inch pully on the compressor and amotor running at 3450 rpm you can get with a 5 inch pully----1189.6 revs per min ---- with a 4 1/2 pully ---1071..6 revs per min so you hve to decide whether you want the max or the min from that compressor... If it was for me I would use the 5in . and set psi. with the cut in ---cut out switch ,this will be a good unit ,,if you need any more help don`t hesitate to call and thanks for the opportunityto help it is great when some one gives you good info .you did well
Aug 09, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Where can i find motor fan part # 2mtr and 3mtr ingersoll rand compressor ssr-ep25
I would try Grainger (www.grainger.com)
They sell IR compressors and always have a large assortment of parts
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Ingersoll Rand Type 30 Electric Driven Two Stage Horizontal Air Compressor 120 Gallon Fully Packaged Ir 2545E10VFP Logo
344 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
