Question about Intermatic Digital 3-Circuit Timer Mechanism P1353ME
I am installing ap1353me. it is set for 220v. i have my pump set up and it works fine. i want to hardwire a 110v uv light into the clock but unsure about the connections. the manual is not very clear. can you help?
P1353 manual appears on following link.
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
P1353 instructions can be hard to understand.
Here is wiring diagram that shows how to add 120V light to P1353 when timer is set for 240V. A neutral wire is necessary to complete circuit to light.
This timer can be wired many ways, so your pump may be wired slightly different.
http://waterheatertimer.org/images/P1353-timer2-600.jpg
Here is additional link explaining 120 and 240 circuits:
http://waterheatertimer.org/240-v-water-heater-circuit.html#120-240
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 31, 2011
I have a 220v pressuretrol connected to my well pump. Also connected was a 220v chlorine injection pump. Recently the pump cratered, had a teck install a new pump, however it is 110V, he changed the wiring...
The 220VAC is most efficient and less costly in the long run. You should not have changed over. Got back to what was working for you in the past!
Jan 04, 2015 | Dryers
Maytag electric range model# MERH752CAS oven and stovetop stopped working.
Check the breakers. The range runs on 220v and one of the breakers may have tripped and it is running on 110v. Post back the results.
Feb 10, 2013 | Kitchen Ranges
Pool pump does not start
Well, this could be caused by several different problems. The first step would be to make sure the breakers are not in a half-trip condition in the breaker panel. You should turn the breakers off and snap them back on. If the breakers are OK, you need to check and see if you have the proper voltage coming into and out of the time clock. Some pumps run on 110v and some on 220v. The proper voltage can usually be determined by the type breakers. Single Pole is 110v, Double Pole would be 220v. You would need a meter to test the voltage at the time clock. If you have the proper voltage, you next need to make sure the shaft is spinning freely by trying to turn the impeller with your finger. If this is free, you may have a blown start capacitor on the motor itself. Hope this helps.
Jul 19, 2011 | Pentair Superflo 1 Hp In Ground Pool Pump
No display on power up got as gift it is 110v but
Did the 220v converter got too hot? Try another larger 220v converter?
Nov 15, 2010 | Vizio VA26L 26 in. LCD HDTV
Over-voltage connection - 220v - instead of 110v
That thing is fried.If you can do your own electronic repair,there are a few components where the plug comes in that would be cheap to replace.Without a solder gun and voltage meter though I would replace.
Jul 20, 2010 | Timex Auto-set Clock Radio
My little giant water pump model 4mdsc has three
Sounds like you may have a 220V pump. So you need to confirm that this is a 110V pump and not a 220V pump. There should be a label or more info on line with any other info on the label. If you can confirm that this is a 110V pump, then put a standard plug on the cord - the green is ground and the other two can be wired to either blade of the plug. If you do have a 220V pump and you connect it to 110V anyway, the pump will perform poorly and will probably overheat and fail.
Jun 25, 2010 | Little Giant SPS25 Water Removal System...
My sony radio alarm clock is too fast about 1 hour. i have moved in the philipines. but my alarm clock is working too fast; ie, it does not show the exact time (about 70-80 minutes) faster
alarm clocks works on frequency and not only on voltage.if it is original 110v 60htz and you trying with 220v 50htz supply then it wont work correctly
Jun 04, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
Have a intermatic t104042 dual timer, it was wired for 240v and ran a pump and lights, now wired for 120v per intermatic's manual....now clock won't runn??? Any answers Gary
I'm almost sure that all T104's have 230V timer motors. You can pop out one of the motors, and see what voltage it is. Or on the label it should say what the clock voltage is. The only way to make motors run would be to connect it to 220V which could still work if you used one leg for each of your 110V circuits. GOOD LUCK
May 02, 2010 | Intermatic T10404R - Two 220 time clocks...
Stove top or oven does not work however, clock
check your 220v outlet, you could have 110v and not the needed 220v to operate the elements. If you only have 110v at the outlet the one side of the double breaker is bad
Apr 28, 2010 | Whirlpool RF364 Electric Kitchen Range
Clock and wiring seem to be working and temperature but oven won't get hot nor burners
CHECK YOUR HOUSE BREAKERS TURN THEM OFF THEN BACK ON.YOU NEED 220V FOR THE ELEMENTS TO GET HOT.110V TO RUN THE LIGHTS AND CLOCK. GOOD LUCK!
ERIC
Jan 16, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Intermatic Digital 3-Circuit Timer Mechanism P1353ME Logo
143 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
