Question about Sony Video Cameras
SONY DCR TRV 230E
Hi all
My camcorder cannot display any video and audio when playback. The camcorder mode change to SP without displaying any hour:minute:sec.
I have used the TDK cleaning tape but only allow 10 sec recording per session. But the camcorder still cannot be used. Please help
5 Suggested Answers
  • 188 Answers
SOURCE: camcorder
if all the indicators i.e. battery condition, play mark, counter, etc are visible on the screen then it can be a simple problem of dirty video head. try using a head cleaning cassette or do the head cleaning manually, Open the cover by removing three screws on the right hand side next to the viewfinder. Slide it little towards front and pick it up. The video head will be visible.
Posted on Sep 15, 2006
philipp
  • 217 Answers
SOURCE: Sony Camcorder playback problem
mechanical alignment! try to record for a minute and playback the result on another player/recorder, not on your camera, if the playback is not okay then your camera needs alignment, you need pro fix. You said that you've done manual cleaning already, maybe you dis aligned the mechanical parts accidentally, applying too much force on the mechanical parts of your small unit tends to bend, dislocate or move these parts out of alignment. defective videohead will never playback good video, and you said that it seems to correct only a few minutes of playback.
Posted on Sep 14, 2007
philipp
  • 217 Answers
SOURCE: Sony DCR-TRV 250
Defective mechanism,
a stucked mechanism is
present. camcorders are
smart. it can detect error
and shut down itself for
safety. earlier models
domino the defect if
the user is not quick
enough to react when
something goes wrong with
the camera. You need
professional service to
fix it.
Posted on Nov 25, 2007
ctf1800
  • 4402 Answers
SOURCE: DCR TVR18E Sony
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 16, 2008
welcomejee
  • 10594 Answers
SOURCE: Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Posted on Nov 24, 2008
How do you switch tape speeds to LP on a Sony Handy cam TRV 240
You can set tape speed SP or LP in record mode only and can not change it in playback mode.
To set tape speed, turn camcorder in camera mode and go to Menu and set SP or LP in record speed option.
Jan 03, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
How to fix choppy audio on Sony DCR-TRV 460 camcorder. Video is ok.
I had problems with playback on mine, and solved the problem by giving it a good tap on the hand strap side of the camcorder.
Hope this helps.
Jason
Dec 31, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Hi8 Playback Problem
Clean the tape heads and see if that makes a difference.  If that doesn't work, it could be the tape motor is going out.  Thats typical behavior when that happens.
Oct 07, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony handycam dcr trv lines problem
You camera Sony DCR-TRV255E requires new CCD Imager and Sony announced to provide Free of Cost repair for subject problem. Please click Sony Support (for UK) for details as assumed you are in UK. If you are living in different country, let me know.
Sep 11, 2008 | Sony Handycam CCD-TRV37 Camcorder
No Image Through Viewer
So your camcorder has problem of No Image in Viewer. Will you let me know this problem is in Camera mode or in playback mode? and this camcorder has 2 viewer, one is LCD and 2nd is Eyepiece. Which one is not showing image?
Jun 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Setting the tape speed
Power up camera on Camera mode, go to menu, select camera settings, go to Record Mode and select SP or LP there. Now your camera is ready to record as per selection.
You can not change speed SP/LP during playback mode because its properties of signal set during recording.
Mar 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony handicam trv skips playback like in slow motion?
you need a computer with at least 1.5 ghz and 1 gig of ram anything less will cause recording to pc problems
Oct 26, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony trv 460 camcorder and HC- 40 mini dv humming noise
The noise is probably the motor running. As long as it doesn't appear on the footage, it's nothing to concern yourself about.
Sep 14, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Sep 14, 2005 | Sony Handycam DCR-TRV460 Digital Camcorder
Video Cameras Logo
124 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
