Question about GE Refrigerators
My GE Refrigerator TFG28PFDA BB doesn't stop working. Is it a problem of gas or ventilation in the freezer inside.
SOURCE: GE refrigerator not cold but Freezer works fine
I have a GE side by side and had the same problem. Upon removing the inside cover I found that there was a substantial amount of ice on the evaporator. Melting with a hair dryer was the short term fix. I have been told, by a reputable appliance repair man, that this is common for GE refrigerators and that the cause is usually a bad defroster heating element. Fortunately you can replace this yourself for about $40.
Posted on Aug 15, 2007
SOURCE: ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Posted on Sep 16, 2008
  • 103 Answers
SOURCE: freezer works refrigerator doesn't ge tbx-25zle
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
Posted on Jun 25, 2009
SOURCE: GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Posted on Mar 29, 2010
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
GE GSS25WTGA BB
This could be a dozen different things causing this. Do you see ice build up on the back wall? Your freezer coil could be icing over and blocking fan air flow. This can be due to a bad fan, low freon.....
Oct 12, 2013 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Mar 02, 2010 | GE GSH25JFT
Freezer and refrigerator compartment to cold
Set both settings at 5 and see if it starts working right
Jan 20, 2010 | GE GSS25LGM Side by Side Refrigerator
Freezer is not defrosting
Sounds as if the drain line in back is stopped up in the freezer section. Sometimes the insulation which is foam the excess settles in the drain area must be cleaned out. You will have to remove the inside of the freezer section to get to it. It;s best to take outside and use a water hose to flush it out. A messy job but it works. BB
Dec 15, 2009 | GE Profile PTS22LHSBB 33" 21.7 Cu. Ft....
GE GSS25LGMF BB refrigerator freezing everything. Refrigerator is set on 1, still freezing.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | GE GSS25LGM Side by Side Refrigerator
GE Refrigerator stopped cooling
I had the same problem. Replaced the damper switch and the motherboard. Then noticed the freezer has frosted over behind the panel in the freezer. Defrosted the freezer and all was working again. The same problem came back about 3 months later. This time the problem was diagnosed as the heater has gone bad in the freezer. Now waiting to have this replaced.
Jun 18, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
