Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Start up problem
My hp dv2100 laptop will not start. the lights come on, the fan is making noise for a second, then a loud beeping sounds comes on for a minute and then nothing. the screen stays black the whole time. I have tried removing the battery, turning it on without the battery and every other possible combination of battery and a/c power. I have had this problem before, but usually it turns back on after removing the batter for a few minutes. But now nothing works. Has anyone else had this or know what I can do?
  • matt76305 Aug 16, 2008
    Sort of the same problem with a friend of mine's computer which I am trying to fix. I've never seen a computer do this, but if you plug the power in, the computer tries to boot, which just turns the power on, no beep..no BIOS screen, nothing. Hold the power button down.. computer turns off. Turning it back on MIGHT boot the computer, might not.. its a real sporadic thing. Doesn't matter if the notebook is warm from use or was started cold.
    Reseated memory, disconnected battery (and clock battery), still same results. I did notice that it seemed to be running a little hot, but no major dust or hairballs came out of the fan area when I blew it with compressed air.
    Computer is out of warranty now, but I have a feeling that this might be happening to quite a few HP Pavillion owners from reading the web, might not be this model, but same symptoms?
  • 268 Answers
Generally, that loud beep you hear is your BIOS (the part of the computer that turns on everything else) alerting you that there is a serious error with it's ability to function. Just for example, the beep could be due to your RAM not being properly seated, your BIOS being damaged or missing, your Hard Drive not being detected, or a non-system boot disk being inserted.
So troubleshooting that particular problem sounds tricky. But I do have a few possible repairs you can attempt that would at least let you know why it is making these error beeps, and go about seeking repair assistance.
1: Remove your RAM from your unit. On the bottom of your computer, you will find one or more small covers that are easily enough unscrewed to allow you access to some of the internal parts of the machine. Underneath one of these panels will be (usually) two thin white slots arranged either back-to-back or stacked as a staircase one on top of the other. These are the DIMM slots for your computer, and should contain your RAM (the green small rectangular circuit boards that contains your your temporary memory). You can release the pressure release on both sides of each stick, and lift up gently to remove the sticks of RAM. The RAM is removed and replaced by inserting it firmly into the DIMM slot at approximately a 45 degree angle. You may only have 1 stick of RAM, but what you need to do is alter the configuration of what you have. Such as: Remove both sticks of RAM if you have two, then only place one into the machine and attempt to turn on. If it does not turn on, repeat by removing the 1 stick and replacing it with it's sister stick. Test and see if it works / shows any improvement. If you have 2 RAM sticks, one might be bad and you can determine if it is by testing both and eliminating each as working or not.
2: If removing your system RAM and replacing it firmly into your unit does not chance the condition at all, next I would suggest attempting to connect an external monitor to the laptop and perhaps producing a video output. Your laptop should have a VGA connection (usually blue, has approx. 15 pins, and is shaped like a trapezoid). Also, your laptop should have a Function key (the F-numbered keys on top of the keyboard) that enables you to switch the video output from the laptop screen to an external CRT or LCD. Usually this is F4, F6, or F8. It should say CRT/LCD or have an image of two rounded squares on it, in blue painted decal, underneath the F-1-12 part of the key.
This might allow you to determine that your screen is bad, and perhaps it will mention why. Lots of possible error messages with that, if it works at all.
3: You can remove the casing from the laptop if you are very careful to notate where each screw is removed from so that you can re-assemble it afterwards. Locate the CMOS battery on the motherboard (it looks like a larger, flat, watch battery). If you remove this, and place it back into the motherboard, you can often cause your BIOS to reset (potentially removing an improper BIOS setting or update).
Otherwise, you are limited to what you can do yourself without the use of full technical manuals and equipment to test the integrity of individual components in the laptop to figure out why it won't post at all.
My personal guess, is that it is a motherboard issue, but saying 'it's a motherboard issue' without attempting some troubleshooting first is almost a cop-out if you're a tech. If it has a warranty, I would suggest having HP repair/replace parts on it under your coverage rather than attempt to solve this yourself, but the steps I've outlined are to the best of my knowledge how you would eliminate possibilities that could be related to your error and no display.
Sorry for the length of the post, but I hope that helps
Posted on Sep 27, 2011
    Scholar:
  • 33 Answers
Hi Irmf,
Sorry for the length of the post, but I hope that helps!
Posted on May 04, 2008
  • Clyde Munsell
    Clyde Munsell May 04, 2008
    I would also like to add, that whenever you are going to be in contact with any internal parts inside the machine or handling any of it's components (such as RAM) it is very important that you are grounded and free of any positive charge. This means: No rubbing your socks across the carpet and then touching the highly electrically sensitive internal components. Very good way to destroy your computer otherwise. Touching a metallic light-switch faceplate is one way to ground yourself, as it contains an internal grounding wire attached to it to prevent you from accidentally electrocuting yourself. Or purchase a 10$ grounding cable and attach it to a grounded object, such as the power-box I mentioned.
    So make sure you don't accidentally fry any of your parts when attempting to access the interior of your machine.
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
My laptop makes loud beeping noise and screen comes up all fuzzy & crazy
sounds like hard drive is bad, replace with new or buy new computer
Jan 09, 2013 | Acer Aspire Computers & Internet
Computer will not come on loud sound from pavillion repeats it self. The fans will spin and the blue light on pavillion comes on. moniter screen will not come on the power light is on
On some computers, when you turn it on, the fan starts to run at 100% of its speed, i.e., very noisily.
Then, when it is detected that the computer is functioning, and _not_ over-heating, the fan will slow down, and quiet down.
So, what is the nature of the "loud sound" ?
Continuous? Beeps, in some pattern?
Take the computer to a qualified technician, for better trouble-shooting.
Jun 09, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Loud Noise from HP Pavillion dv9500
it could be a worn speaker wire shorting out
Jul 01, 2009 | Computers & Internet
I have a HP Pavilion dv6000 and the fan has started making noises
Its possible but it would require taking out all the screws from the bottom of the latop, taking out the keyboard and the screws from the top cover. Then disconnecting the ribbon for the mouse pad and any other plugs coming from the top cover. After you take off the top cover you'll expose where the fan is at and at that point you can clean it off. If it still makes weird sounds then the fan would need to be replaced.
Jun 08, 2009 | HP G60-120US Laptop
Loud noise from speakers when laptop closed/standby
Hi there.
Your microphone is on, and when you close the lid it is closer to the speaker. It needs
a loud noise (like closing the lid faster) and it enters into a feedback loop.
We need to find a way to make the microphone not play back.
Try left clicking on the speaker icon in the bottom right of the screen, and click playback
options. Here mute the microphone, and see if it solves your problem.
Good luck
Jun 04, 2009 | HP Pavilion dv6000z PC Notebook
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Hp computer will start, all the lights come on but the screen is black.. also.. it makes this loud beeping noise 4 times?? whats wrong?
The beep is more than likely a beep code (sounds stupid and obvious, but they're there for a reason).
What make/model is your machine? We can look up the code by make/model. That will diagnose your problem.
May 16, 2008 | Sony VAIO VGN-N250E/B Notebook
Beep from computer
My lap is also dv6000 and i have no symptoms like that.
it seems some thing is going wrong inside. As your lap is under warranty you should contact your service centre, it will be free.
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire One PC Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
301 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
