Question about Micro Innovations PD7250LSR Wireless RF Laser Mouse
I have a Model KB1100W keyboard and suddenly it wont connect to my PC although I changed the batteries and push the connect bottom many times. on the other hand my wireless mouse is performing well. what is the problem? i bought this unit from frys 2 months ago. is this still under warranty?
preachw996
  • 1179 Answers
SOURCE: Wireless Keyboard Trouble
Replace the batteries and retry. Hope this helps.
Posted on Dec 26, 2008
bharrie
  • 158 Answers
SOURCE: both my pc and laptop wireless mouse quit working today
- usually this happens if you have changed the ports of the wireless receiver attached to you computer.
  • Unplug the receiver and replug the receiver
  • Ensure that you are using new set of batteries
  • If you have a connecting sequence, try performing it again
  • Check if the drivers are in place (Click Start > Run >Trype 'devmgmt.msc' without quotes. Hit enter)
  • If necessary install the driver from http://www.bioticaindia.com/pd7250lsr.html
  • If none of the above steps works, maybe you need a replacement from Micro Innovation for this device.
Posted on Jan 08, 2009
yooperbud
  • 8637 Answers
SOURCE: installing my wireless keyboard and mouse
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 20, 2009
cpenzes
  • 1102 Answers
SOURCE: I just bought aused computor
you probably have a reset button on transmitter and posibly on bottom of mouse make sure you reset them
restart pc and if it still does'nt work I would run software again
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: had to change batteries, now keyboard wont work -
try to reinstall the software... and sometimes just try restarting the comp
Posted on Aug 07, 2009
Lenovo thinkpad t400 laptop wont open
try changing the keyboard because switch is on keyboard and use adapter to plug and test
Mar 25, 2014 | Computers & Internet
Tip
Wireless Mouse and Keyboards reconnecting
Not sure how helpful this will be to a lot of people but one of the common questions seems to be how to reconnect after changing batteries IE changed batteries and now my mouse/keyboard won't work at all.
Seems that most of the time people forget that they have to
1- push the connect button on the usb receiver and that should be right on top of the unit since these ones are not usually hidden and are easy to push without the paperclip
2- push the connect button on the mouse/keyboard (needs a paperclip)
Once that is done the devices should find each other and establish the connections to each other again. These connections should remain in effect until the batteries die on you again at which point you will need to do this procedure again.
Should also note that the connect buttons on either your mouse or keyboard are small buttons and usually recessed in the bottom of the devices, this keeps them from getting hit or pushed all the time, so a paperclip is usually recommended to push the buttons with. Also as a final thought connections need to be made fairly quickly so check out your devices to see where the buttons are located at and get your paperclip ready, you only have somewhere between 5-15 seconds to make the connection or else you have to start the whole thing all over again.
Hope this helps some of you
on Jun 27, 2011 | Computers & Internet
I recently got a Vibe keyboard and mouse as a gift. Both are wireless and use one USB plug together. The model number is Kb-262. I can get the mouse to connect, but the keyboard will glitch and suddenly...
yer you are,switch the computer off, then plug in the keyboard & mouse...i'm thinking the GREEN ps2 port for the mouse & USB for the keyboard...
put batteries in them both,make sure their not dead batteries, then locate the little connect button on the bottom of them both, & the one on the receiver as well.
get a pin or something of the sort, so you can press these connect buttons.
switch the computer on, then once its booted up..press the button on the receiver @ the same time as the connect button on the keyboard,if not then the receiver first then the keyboard.
once connected, do the same with the mouse......receiver button then mouse connect button or both @ the same time...
you'll get it in the end,you'll need to do this ever time you change the batteries.
GOOD LOOK!
Sep 10, 2011 | Computers & Internet
My wireless mouse stopped working; I changed the batteries and still no light. Can you suggest a solution? I tried the connect button but no change. Thanks for any help!
usually there is a button on the bottom of the wireless mouse that you can push at the same time you push the button on the mouse adapter on the pc. Simulataneously push both and see if that doesn't help.
If that doesn't work, change batteries. If that doesn't work, uninstall the mouse and reboot. Software should reinstall.
Jul 06, 2010 | Logitech Cordless Mouse
HID keyboard (ACER) FCC ID: E8HKBR0355 Model number: KBR0355 stopped suddenly although the keyboard is working, changed battery but not working
i have restarted my PC and as my mouse is working, i make sure the the wireless connector is working i pressed the button at the middle of it to make it blink contentiously and then pressed the button at the bottom of my keyboard, that is it.
Dec 16, 2009 | Acer Wireless WIL-152 91.84R07.152...
Keyboard wont connect
Hello
I've had the same problem with the Keytronic stuff. Most of the time new batteries solve the issue. Once, though, batteries didn't help. I discovered that if I wiggled the batteries it would work. I tried an old trick. Using a straw, put a drop of Coke on the connections. Scrub the area with an old toothbrush. If there's residue use rubbing alcohol to remove it.
Good Luck
Sep 24, 2009 | Logitech Computers & Internet
Wireless keyboard went dead. Have changed batteries & pushed all green buttons
I had the same problem with my keyboard and it turned out to be a manufactureing problem I just got another keyboard.
Apr 20, 2009 | Dell Dimension 3000 PC Desktop
Microsoft Keyboard & Mouse not working
Hi there
Remember to check the batteries and press the connect buttons underneath the keyboard and on the mouse or mouse docking station
post back if no results
Kind regads
Feb 18, 2009 | Microsoft EF1330255 Keyboard/Mouse
I have the logitech bluetooth keyboard with the separate number pad (not connected but came with it). I love it and it's worked great, but it suddenly stopped working a couple of days ago. I switched the...
you have to push the connect button on the keyboard mouse and the receiver to reset all of them. It sounds like you just have to push the button on the receiver and the keyboard
Jan 21, 2009 | Computers & Internet
Micro Innovations PD7250LSR Wireless RF Laser Mouse Logo
383 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Joseph Hoffmann
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
