Question about Whirlpool MH7140XF Microwave Oven
Code f6 on. followed the the instructions on the faq site, unplugged for 2 hours then plugged it in and it is still throwing up code -F6- i would like to know why it is throwing that code
  • 10,515 Answers
This is a bad error. It refers to microwave relay failure.Check the wiring to relay for short circuits.If wiring is OK, you need to replace control board.
Sometimes it is due to stuck relay.With the door open unplug the microwave oven. Then whack ( light ) on either side of the keypad a couple of times. That might fix the error. ( usually this is done by tech's ).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 22, 2010
  • john scanlon Nov 10, 2011
    taran_2005>>>thank you! Just tried this trick and it worked!
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
ERROR CODE F6 SOUNDS LIKE IT RUNNING. UNPLUGGED IT AND PLUGGED IT IN AND WHEN I SHUT THE DOOR SAME OLE
Hello lyle,
The reason your microwave comes up with the error code f6 is simply because there is a shortened key, also know as a bad relay. I bet you have a kenmore microwave oven there.
It will act like it is about to start working, sometimes, the tray would roll inside the oven, but will not work.
You need to check wiring to relay 4903 for short circuit, then correct the short circuits you seen.
Hope this helped you.
All the best.
Elect_Comp
Dec 12, 2011 | Microwave Ovens
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
I have a Whirlpool MH7140XFQ-0 Microwave and last night it stopped working with the screen showing F6. I unplugged it for over an hour and plugged it back in and it went right to F6. It tries to run if the...
"F6" on a Whirlpool microwave means you have a shorted cook relay on the control circuit board.
For model MH7140XFQ0 the control circuit board would be part number 4393919, which you can order from the Pros here for $132.23.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) take out the old board, then move the new circuit board into your frame.
Some connectors on the relays may have a lock:
Otherwise, we regularly repair these boards with our $39.95 nationwide service. Details are here.
Jan 23, 2011 | Whirlpool MH1140XMS Microwave Oven
My oven displays F6 and will not work
This more less just like pc,you can unplug it for about 24 hours it wipes out electrical chips.Then you plug it in usaully works everytime.Or if you have password this will help you reset to.F6 iam not aware of it special features,but tried this above.thank you for your question.
Aug 08, 2010 | Kenmore Microwave Ovens
Whirlpool wmh1162xvs service code F6 after power failure
This is almost always a shorted microwave power relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Or feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 14, 2010 | Microwave Ovens
I replaced the light bulb, now it displays -F6- and pushing any button causes a humming noise.
I left the unit unplugged over night, plugged it back in the next day and still had the same problem.
Oct 13, 2008 | Roper Microwave Ovens
What does -F6- code stand for?
F6 means a problem in the control circuit board.
Try unplugging the microwave with the door open, then plug it back.
Try the solution that you find here, if it does not work the panel must be replaced.
Sep 10, 2008 | Kenmore 63652 Microwave Oven
Kenmore Microwave hood combo Model # 66569689992 F6 error code?
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Dec 08, 2007 | Microwave Ovens
Whirlpool MH7140XF Microwave Oven Logo
85 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
