Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
Banging noises like steel hitting steel when turning-what is the problem
    Novelist:
    Champion:
  • 232 Answers
Make sure that the deck cover fenders is not hitting your drive tires. Check the bearings in your caster wheel assembly to ensure the casters can turn freely. The back outrigger has a pinch bolt in the middle, tighten it all the way then back off 1/2 turn.
If these do not help, you may have damaged the frame, axles or mounting bracket for the motor. This can happen when the rider weighs too much for the power chair or the power chair has been dropped onto the ground.
If you continue to have problems, contact Pride for Tech Support.
Posted on Oct 20, 2010
Knocking noise on suspension
I had the same problem in my sportage.....it was the disc caliper clip...it might have lost its tension or you might have had some repair work and mechanic forgot to place clip.....
Hope it help
Regards
Asad
Mar 27, 2014 | 2012 Kia Sorento Base 4dr SUV 2.4L 4-cyl....
Banging noise when you drive
This is a hard problem to describe, I know, and I will toss out a few possibilities. If the noise occurs when the car is accelerating, it can be motor mounts, or carriage mounts on front-wheel drive vehicles. Transmissions can bang into gear. Drive shaft u-joints can bang before they fail. C-V joints in front wheel or 4 wheel drive units can bang when worn out.
The exhaust system can break loose and bang on the frame. Brake calipers can rock in their mounts and transmit sound. Tie-rod ends can make a knocking noise on every bump you hit. There were recalls on gas tank straps for some Ford made units, so a loose gas tank can bang.
Dec 30, 2013 | Mercury Cars & Trucks
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
The GE side by side is roughly 10 years old and when the turbo cool bin is on it makes a rattle noise every 5 mins. like a toy gun sound. I turn it off and it stops. It only happens when the bottom bin...
It's freezer fan hitting with your bin drawer when it's over ice formed behind the freezer. It's due to malfunction of defrosting. Keep 5 degree thermostat setting. And check thermostat by turning counter clock wise. If shuts off the fridge, it's working. If not replace thermostat. Check defrost timer set in proper setting. Once defrost cycle is good, no banging sound will be there. Thanks.
Feb 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hot water: Pipes make a banging noise when turned on full force.
Hi, That banging is sometimes called a water hammer. It is made when the water hits an elbow in the piping with a force and bangs into the pipe itself. It is more likely to occur in a long run of pipe. This can be reduced or eliminated by installing an empty tube verticle in the piping near where the hammer is occuring. This tube can be found at most building supply stores. The tube is a pocket of air that acts to absorbe the extra pressure from the piping and stops it from hammering.
May 05, 2010 | Delta 2 Handle Lavatory With Metal Pop Up...
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
Loud banging noise
check to make sure the metal cover is not hitting the rotors /thaks for using fix ya Please rate my response thank you very much
Jan 31, 2009 | 2001 Hyundai Santa Fe
Banging noise come from the suspension
ON MINE IT WAS THE WISH BONE BUSHES, CHANGED ALL WITH THE POLYUATHANE DONE THE JOB
Jan 26, 2009 | 2003 Chrysler PT Cruiser
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
82 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
