Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
My dishwasher leaves a white film on the dishes even though I put in a rinsing agent. what can I do?
    President:
  • 1,197 Answers
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
2) Adjust the detergent amount.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Posted on Sep 03, 2010
My dishwasher leaves a soap residue. I use a rinse agent. Any suggestions?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The dishwasher leaves a film residue over all my glasses and other dishes. I changed detergents and rinse agents and it still happens
heatman101
Jan 12, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
After 3 years, my dishwasher started leaving a white residue even with a rinse agent. The dishwasher also looks white inside; what can I do?
heatman101
]]0]0
Dec 11, 2010 | Frigidaire 18 in. FDR252RB Built-in...
Dishwasher seems to run for a very long time on normal cycle. It leaves a whitish residue on dishes and the glasses appear cloudy. I do use a rinse agent.
heatman101
Nov 21, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
My dishwasher is leaving a thick flaky residue on all my dishes and we use a rinse agent on nearly the max setting. The Heating element doesn't work.
heatman101
Jul 26, 2010 | Whirlpool 24 in. DU1055XTP Built-in...
My maytag dishwasher doesn't seem to be rinsing
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 25, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
My brand new dishwasher leaves white film
The new washer is drying the dishes faster that the old one,Try setting it to no heat dry and see if that helps,if so you will need a water softener or filter for the water line to the washer.
Jul 29, 2009 | Dishwashers
White film inside the dishwasher and on dishes
Usa a liquid detergent and rinse agent. Make sure your water is above 120 degrees. If you are a hard water area, use a detergent containing a water softener.
Mar 25, 2009 | Siemens 24 in. SL34A006UC Built-in...
Dishwasher leaving a film on dishes
usual cause is rinse agent not being taken. check that level of rinse agent lowers over time
Apr 20, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
252 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
