Cut wire by accident outside - Heating & Cooling
    President:
  • 3,773 Answers
Put it back together with a wire nut and tape it securely
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 22, 2010
Lexusrx350 won';t start after ground wire was cut by fireman in an accident joined wires no power to ignition
cutting the ground wire [probably energized the immobilizer
same as removing the battery
try resetting the ECM using a scan tool
Oct 02, 2015 | Cars & Trucks
1999 Chevy Malibu LS wire diagram from BCM to PCM all interior wires
go to www.autoelectronico. com translate the page to english and search your topis for wiring diagram according to your model, etc.
God bless you
Oct 16, 2012 | Cars & Trucks
Lincon ls v8 3.9
If you think that cutting the wire is what is causing your car to not start. I would say that the solution would be to splice the wire back together.
Apr 25, 2012 | 2000 Lincoln LS
I need to re wire the fan clutch the wires were cut on accident. a diagram of how to do it would be great.
Look at the wires that were cut.The plastic coating on the outside of each wire has different colors on them.Just rejoin each wire to match the colors.Hope this helps
Mar 27, 2011 | Dodge Ram 2500 Cars & Trucks
I had a viper remote starter installed in my 2005 CRV and now my cruise control doesn't work. Dealer states not there problem...
Yes it is their problem if they installed it. Most likely unplugged a wiring harness by accident (or even cut into wrong wire or cut wrong wire) under the dash. Tell them you want you money back unless they fix it.
Jan 07, 2011 | Viper Security and Remote Start System...
Wire inside is torn
Hello
This tends to happen eventually with headphones, mostly by accident. I know.....
Things that you will need are a soldering iron, screw drivers and such.
You will have to disassemble the headphones, begin by removing any visible screws, you may have to carefully remove the soft pads around the ears to expose screws.
eventually you will get it open.
It is pretty simple repair. You have to cut the old wired out, possibly expose some new wire and then solder on its place.
When you got the wires in properly again, plug the headphones in and listen if you get sound from both, if these include a microphone also test it.
Then reassemble the headphones.
Let me know if you require further assistance.
Thanks,
Ekse
Feb 27, 2010 | Sentry HO900 Headphones
Can the (cut) wiring be repaired on headphones?
Yes it can, strip the wire's off, re-connect them & tape well with electrical tape avoiding any shorts & you should be working again.
Jun 20, 2009 | Audio Players & Recorders
Cut red and white wire outside no longer have power to the fan.
Turn it off at the breaker. Strip about 1/4" insulation off each wire. Run down to Home Depot and buy one of those water-proof wire screw kits that water will not penetrate when it dries.
Come home, take the wire nuts out, twist the two ends on one color together and pour in the epoxy; Twist until tight as you can get. Then do the other one. After the epoxy sets up you'll be okay as long as none of the wires are exposed through the insulation. I would bury them if you have enough slack.
Sirwriter
May 25, 2009 | Bryant 462AJC021BA Air Conditioner
Outside temp stuck on -40
when its at -40 usually its because the ambient temp sensor is not sending the proper signal to the controller.. it may just be disconnected.. the sensor it behind the grille.. it has a 2 wire connector to it ... itf its connected it may havea broken wire from body damage in an accident... its rare that the sensor fails..
Jan 30, 2009 | 2001 Chrysler Town & Country
I cut a speaker wire
well I have in the past been able to strip the rubber back to the bare wire on both ends and then twist them together. use electrical tape to cover any exposed wire this should fix it.
Jan 25, 2009 | Durabrand 5.1 Surround Sound Computer...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
