Question about Swisher 44-Inch 12.5 HP Trailcutter #RTB12544
I'm trying to replace a belt on a 44" trail mower. How do I tighten the belt??L
  • 86 Answers
SOURCE: How does the belt go on a 18/44 Lowes Mtd mower
You should get the same belt that came with it, they tend to last alot longer ! Most of the time the deck has the diagram on the deck to show how belt goes on,sometimes under the pulley guards, you can also type in your model in google you should get good results.I can also help you with getting belt at a good price.
Posted on May 13, 2009
wadembly
  • 475 Answers
SOURCE: I am trying to replace my mower deck belt. I
got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
Posted on Jun 08, 2009
woobie dog
  • 1273 Answers
SOURCE: How do I tighten the mower belt on a lt1000?
It is kept tight by a tensioning pully. If it is loose, replace it.
regards, --W/D--
Posted on Jul 21, 2009
suzukiracing
  • 200 Answers
SOURCE: 44" v-belt needs to be replaced
Look under footrest for diagram on sticker.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
Dirt Dobber
  • 253 Answers
SOURCE: trying to tighten a belt on riding craftsman lawn
Most are tensioned with a spring only make sure they are all there.
Posted on Aug 10, 2010
How do I tighten my drive belt on my landlord simplicity 44 inch cut. it seems to work good in Reverse forward wants to slip going up hill more
You need a new belt, if that's the original belt then itshe time for a new one as that original is worn....it happens... the belts are made to be tight already, there is no adjustment.
Oct 04, 2015 | Garden
What size is deck belt for swisher trail behind 44'' modelt11544
Swisher 4220 74-Inch Belt - Fits select Swisher 44-in, 42-in and 22-in Mowers
Jun 22, 2015 | Swisher Garden
Swisherinc com
if by floppy do you mean that tips move up down 1/2 inch yes this is normal, if they move more ck spindle bearings ill bet your missing a few balls in there , and nope no belt should have chunks missing , and yes defective belts will slip and not get proper blade speed from engine to blades
clean out belt path after every use , that belt guide path is a magnet to sticks and stuff collecting there , also allways use kevlar belts , not ones from a car there not 4 to take the heat a kevlar belt will
Aug 18, 2014 | Swisher 44 in. 12.5 HP Briggs & Stratton...
What causes belt shredding on swisher pull behind mower, 44" cut, 11.5 hp
how old is your trail mower? have you checked the pulleys for the belt drive? possibly the pulleys are loose, or the shafts holding them are worn and wobbling causing a misalignment of the belt, in turn shredding the belt. also check the pulleys to make sure they are smooth, allowing the belt to move cleanly
Jul 18, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
My Swisher Rough Cut 12.5 HP 44 Inch mower - The blades stop cutting when I hit a dense patch of grass. The belt and the pully are still moving at normal speed but the blade slows. Also I can spin the...
I dont believe there is a shear pin on your blade spindles, what I have found on these machines is the the spindle nuts on the balde spindles sometimes loosen or wear and no longer squeeze the pulley on the blade spindle. To make this process easy on your self you need to tighten these with a impact wrench. However if you dont have access to a impact wrench you can use hand tools and block the blades you are trying to tighten with a wooden block. Just make sure you block the blade you are trying to tighten
Aug 13, 2009 | Swisher 44-Inch 12.5 HP Trailcutter...
Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Logo
83 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
