Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
My printer has not been used for a while, and I have just replaced the ink cartridges. I am still getting nothing but blank or VERY faint pages. Could my printhead be clogged, and how would I fix it?
  • 245 Answers
Hi
Most likely the print heads are clogged.The old ink sets up and dries out over time and lack of use.The link is to a how-to article on an easy way of cleaning the heads.
If this helps,would you rate my post?
Thanks
Bob
http://www.atlascopy.com/newsletters/How_To_Clean_Clogged_Inkjet_Print_Heads.htm
Posted on Aug 22, 2010
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
My ink cartridges are full however when I print something the paper comes out blank or with very, very faint lines. I have taken the ink cartridges out and shaken then but that didn't help. Not sure what...
Remove the cartridge and clean the electrical contacts with a q-tip and bottled or distilled water (do not use alcohol, this can cause problems). DO NOT CLEAN THE HEAD AREA.
Clean the contacts in the cartridge carriage as well.
Make sure you removed the protective tape from the ink cartridge. It may have ripped and still be covering the head area.
reinsert the cartridge.
Try printing about 5 pages.
If the 5th page is still blank, either the printer is defective, the cartridge is empty or not a genuine Dell cartridge, or the cartridge is defective (in this case, call 310-DELL and get it replaced).
if the printer is defective (IE - if you tried ANOTHER cartridge, and are getting the SAME results) then the printer needs to be serviced. If it's under warranty, call Dell - they will replace it.
Feb 25, 2011 | Dell 926 All-In-One InkJet Printer
I have an Epson CX4800 that just stopped printing. I followed the Troubleshooting steps on the Epson site (including new ink cartridges) but nothing has helped. the print job does reach the printer - but...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 28, 2010 | Epson Stylus CX4800 All-In-One InkJet...
I havent used it in months i shake the inks and they have some inside but when i try to print i get a blank page
It seems that Epsons ink clog up after sitting.
You may need to bring the headd over as you were to change cartridges and remove them.Unplug machine.Now take 5 or 6 drops of ammonia and put them in the ink well hole.Re-install carts and let it sit for 45min to one hour.Plug back in and do a nozzle check.If someyjing comes out but faint repeat process until happy.
If this does not work you may have to get a new head,usually less expensive to invest in a new printer.
Always run a test page weekly on an Epson to prevent this from happening again!!
Jul 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Page blank when printed
remove the ink cartridges and use a qtip dipped in rubbing alcohol and GENTLY clean the printhead on the cartridge. Reinsert and try printing again. If it prints anything at all, keep going till it becomes normal. If still nothing, replace the ink cartridges.
Jun 23, 2009 | Dell Inkjet 720 Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Printing but blank pages coming out .
Take the ink cartridge out of the printer. On the bottom of the cartridge, there's a copper/gold surface with bumps and holes. Take a napkin or peice of paper and rub it on this surface. This serves two purposes - if there's any dried ink or blockage, it will help clean it, and it's a test to see if there's any ink left in the cartridge. On a normal ink cartridge, rubbing paper on the bottom would cause some ink to smear onto the paper. If nothing wet comes out, the ink cartridge is dried out or empty. You'll need to replace it.
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Printing blank
If not printing anything go to printer properties and print a test page. If nothing visible replace cartridge. Cartridges known for drying up when not frequently used. Use cotton swab with rubbing alchohol to clean any dried ink from ports and reciever.
Apr 25, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Jun 17, 2008 | Epson Stylus C60 InkJet Printer
Print page comes out blank
If the cartridges are old too this may be a problem. When ink gets old it can clog the cartridges. If they are old replace them with new ones. If they are new ones did you peel the protective covering off before you inserted the cartridges? Hopes this helps
Sep 16, 2007 | HP DeskJet 952c InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
55 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
