Question about Kodak EasyShare DX7630 Digital Camera
High camera temperature easyshare dx7630 - Kodak EasyShare DX7630 Digital Camera
SOURCE: My screen reads "camera error # E21"
On my LS 743 Kodak Camera, that error refers to a lens mechanism problem. I was able to fix it by removing my front cover which had be come dented inward and short circuited some wiring. Re-shaping the cover fixed the problem. This will probably void your warranty...
Posted on Aug 13, 2007
jackboy
  • 2985 Answers
SOURCE: Kodak EasyShare DX7630 Camera
Check the ASA setting - read up the manual
Posted on Jul 19, 2008
tjjfitz
  • 8 Answers
SOURCE: Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Posted on Oct 21, 2008
Neerak21
  • 101 Answers
SOURCE: my kodak easyshare z740 lists an error high camera
Here are the steps:
1. Make sure you will install a new or fully charged
battery/batteries into your camera.
2.Remove the battery/batteries and the memory card from
your camera
3.Reinstall the battery/batteries into your camera
4. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Posted on Sep 24, 2009
SOURCE: kodak easy share dx7630
Kodak online tech support couldn't help or explain the problem just offered a discount on a new camera or I could send it to an authorized service center (I'm sure it's worth that!)...tried the bumping on top, bottom and sides....It works now!
Posted on Mar 17, 2010
Bought a 8 gb sd card for my kodax dx7630 and says it needs formatting, but then goes back to need formatting. to large? thanks
The DX7630 works with MMC and SD cards, 2GB or smaller. Your 8GB card is actually an SDHC card, and the DX7630 will not recognize it.
Sep 08, 2013 | Kodak EasyShare Z740 Digital Camera
How do I upload pictures from my Easyshare dx7630 to my Macbook Pro iphoto 09
Upgrade your Mac Os to Mac OS X 10.6.2,then it gives you a good result
Sep 09, 2010 | Kodak EasyShare DX7630 Digital Camera
"High camera temperature"
this worked for me: just hit the bottom hard with your palm and the top and sides, not the front or back. After 3 hits, the date screen came back on and it was fixed. This was after the other two solutions I found on this site failed, namely pushing the shutter down before the message comes on or blowing into the camera slot with the memory card removed.
Jul 28, 2009 | Kodak EasyShare DX7630 Digital Camera
Grey cradle that surrounds the joystick is jammed?
Have you found a solution to this? My camera has the same problem.
Jun 09, 2009 | Kodak EasyShare DX7630 Digital Camera
Kodak Easyshare DX7630 screen is black and won't take anymore pic
your image sensor is bad it will have to be replaced by a camera technician .
Jun 03, 2009 | Kodak EasyShare DX7630 Digital Camera
Jul 18, 2008 | Kodak EasyShare DX7630 Digital Camera
HIGH CAMERA TEMPERATURE warning
As stated X Ray machines should not affect camera or images. Best to check this out with Kodak I am not aware of any other camera to have this sort of warning.
Sep 12, 2007 | Kodak EasyShare DX7630 Digital Camera
Kodak easyshare DX7630
X Ray machine would not harm the device. What Hi temp means I do not know- discuss it with the Kodak Support site.
Jun 21, 2007 | Kodak EasyShare DX7630 Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
