Question about Hayward Phantom Pool Cleaner Complete with Booster Pump
Phantom does not move gets stuck in one spot - Hayward Phantom Pool Cleaner Complete with Booster Pump
  • 640 Answers
Is the cleaner getting stuck at steps, corners, etc? If so, your spin out is too short. Change the cam to the "winter" position to increase the pool cleaners spin out.
Posted on May 24, 2011
C1 not working
Sounds like your Phantom power supply may be defective. To be safe, 1st try moving AC plug for Phantom supply to another outlet as sometimes "sharing grounds" can be a problem. If this doesn't help, try using another phantom power source ...many PA mixers have built-in phantom power. If the buzz disappears with a new one, it will be a filtering issue (capacitors) with the old phantom supply.
Apr 19, 2014 | Behringer C-1 Microphone
Black spots like little bugs on screen and some white spots
optical engine failure. that technology is called DLP digital light processing and it uses a device called a DMD digital micomirror device that has millions of mirrors onthe face and they independtly move and sometimes they can get stuck or not move and cause spots black or white across the entire picture. i suggest calling customer support for possible repair accomodation
Jan 12, 2011 | Samsung HCN4226W 42" Rear Projection...
My Hayward Phantom cleaner spins continuously.
Mine had this problem too 6 months ago and I successfully fixed it . I will try to describe the remedy as best I can. I will use the same part names that Hayward does on their diagrams (easily found on google). The unit has 2 pistons that are attached laterally to the manifold. They move in and out slowly to direct the flow of water for the "turn around" function. They seem to be the root of many problems that long term phantom owners are all too familiar with.
Essentially, the pistons get bound-up or stuck over time or the cylinder caps on the ends leak water. First remove the cam cover on the top of the unit (while the pump is running) and determine if your turn around cam is working. If it's not turning, then the gearbox may be broken.
To lubricate the pistons, you will need to remove several components so that you can remove the manifold assembly. If I recall, you can do it without disconnecting any rubber hoses. Once you get to the manifold, tilt it up so you can get to the cylinder caps on the left and right side. Very carefully remove one of the caps by gently prying the plastic tabs. Inside, there is a plastic piston with a rubber seal. Mine were stuck and difficult to move. The pistons should slide easily. I lubricated the indide of the cylinders with pool and spa lube from Lesl***. I pressed the cylinders back and forth until they began to slide freely. I reassembled everything and it worked like a charm! No more "death spiral". On one of my phantoms, a cylinder cap tab broke off and was leaking. I used a large zip tie diagonally to hold the cap on. It held permanently.
The Phantom is not a trouble free unit by any stretch, but I do think pool stores have taken advantage of the situation by often unnecessarily replacing major components. I'm basing this on some of the posts have read in pool foums. It reminds me of German car dealerships!
Aug 07, 2009 | Hayward Phantom Robot Cleaner without...
Spin of death
Add a comment
Aug 01, 2009 | Hayward Phantom Pool Cleaner Complete with...
Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
May 26, 2009 | Pentair Jet - Vac Pressure Side Inground...
How to get throught the phantoms on legand of zelda
to get to the next level you stay on the safe spots til you light the torches.'K.
Mar 15, 2009 | Nintendo The Legend of Zelda: Phantom...
HELP!!
NO, you run into it, not stand on it
Feb 03, 2009 | Nintendo The Legend of Zelda: Phantom...
Zelda & the Phantom Hour Glass on DS Lite - Stuck please help!
try gfaqs..games frequently asked question..you can download a walkthrough for your game
Mar 22, 2008 | Nintendo DS Lite Console
Sat stuck on one spot
Can you still access the menus or has it locked up totally?
If it has locked up totally, there is usually a tiny recessed reset button that you can press to restart. failing that, try holding down the power button for 10 seconds
Then take it outside somewhere where there is plenty of clear blue sky and turn it back on again. It might take a while to get a good satellite lock, but it should come back.
Sat Nav systems do not work well indoors, which is where most people want to test them.
Jan 13, 2008 | Audio Players & Recorders
Hayward Phantom Pool Cleaner Complete with Booster Pump Logo
216 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
