Question about Honda Black Max 2600 PSI Pressure Washer
Water will not come out of wand on my Honda Black Max 2600 PSI. Please help
  • 21 Answers
Have you tried differnt tips?
Posted on Aug 29, 2010
Engine stalls when not using wand
Frank, either the unloader valve is out of adjustment(try loosening it off) or it is faulty and needs rebuilt or replaced as most people do.
Check the attached vids,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 15, 2016 | Honda Black Max 2600 PSI Pressure Washer
Suds won't draw from tank
make sure the hose from the tank is not split or cracked where it draws from the tank
Aug 18, 2014 | Honda Black Max 2600 PSI Pressure Washer
Honda blackmax 2600pressure washer will not start
Is the gas tank topped off? Is the water hose plugged into it and turned on? Is the gas valve open instead of closed? is the throttle turned on fully? Is the spark plug wire attached all the way? Should work after all of this.
Jul 12, 2014 | Honda Black Max 2600 PSI Pressure Washer
Troy bilt 2600 psi when you turn the water on it shoots out through the chemical supply inlet
My chemical supply inlet has a checkball and a spring that keeps pressure in check. There must be debris behind checkball. Easy to check by removing the fitting. If faulty and parts not available, plug fitting and add an aftermarket injector from www.pwmall.com. that you can install when you need it. Good luck
Sep 30, 2011 | Honda Black Max 2600 PSI Pressure Washer
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
How do you drainoil so you can change the oil in Honda Black Max 2600 pressure washer?
lornaa, you can get a copy of the user manual from this link. It has come directly from the manufacturer.
thanks and good luck
iain
May 04, 2011 | Honda Black Max 2600 PSI Pressure Washer
NEED A LONGER WAND
What size wand are you looking for? The most popular sections of wand that we sell are 8 ft and 12 ft.
Oct 09, 2010 | Honda Black Max 2600 PSI Pressure Washer
Honda Black Max 2600 PSI Pressure Washer Logo
246 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
