Whirlpool washer model GHW9150PW0 control lock light on will not start a cycle
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
Duet Washer Won't Start; Outlet Fine
How old are they & where did you get them from?
Jan 30, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Getingcodef71onwasherwasherwillnotstart
An F71 error indicates that the control panel (the buttons you press) is not communicating with the central control unit. Open the panel and check if there is continuity to the control panel wiring harness. Make sure that the wiring harness is fully connected to the user interface panel and the central control unit. Depending on if the drum rotates, you need to replace the user interface or the central control unit. (If the drum rotates, then it's probably the user interface. Otherwise it's the central control unit.)
Whirlpool has the parts diagram for the GHW9150P on their site in the Manuals and Literature section. The direct link to the parts list for the GHW9150PW0 is: https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208180440.pdf . For other models, enter the model number and click search on this page: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . This site has the parts for the GHW9150PW0: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136839&diagram_id=28192106 . If you have a different model, start here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ghw9150p .
I hope this helps.
Oct 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water goes into the washer (model GHW9150PW0)
your inlet vaulve is sticking and allowing water to trickle through, only solution is to find if it is your hot or cold vaulve and replace it
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Nov 19, 2007 | Whirlpool GHW9200L Front Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
