Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John Deere LA 175 Parking brake is stuck. Any suggestions other than removing the deck to diagnos and fix the problem?
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
  • 66 Answers
SOURCE: L120 JOHN DEERE
There should be adjustments on the tie rod ends connecting to the front axles. Loosen set bolt, make the adjustment and re-tighten set bold.
Posted on May 30, 2010
SOURCE: John Deere ride on mower L100 17 hp.
my ride on runs well for 5 miutes then just stops wait a few minutes starts right up but does this over and over some help please
Posted on Jun 23, 2010
farmerbear
  • 490 Answers
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
Posted on Aug 21, 2010
  • 3 Answers
SOURCE: I need a diagram of the belt on a black deck John
Follow this link: http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt then do a "model search"
click on which model (either yellow deck or black deck) alphabetically pick which belt,
a diagram should appear in the right hand corner.
Or this website:
OutdoorPowerInfo.com © 2011
Or just 'google':
Installation of John Deere STX38 and STX46 Hydro Drive Belt (Black Deck)
Good luck.
Posted on Mar 05, 2011
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/...J7/Output/OMLVU17926_J716.html
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM139226.../OMM139226_A99.html
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
John Deere 262 parking brake won't disengage. Stuck in neutral and won't move
Marti: According to GreenTractorTalk.com, T Mo said: "A couple of things come to mind, first is the brake sticking. Second is the brake linkage needing adjusting, therefore not releasing the brake. Thirdly, the linkage for the gears itself." This YouTube video shows brakes but not for your model: https://www.youtube.com/watch?v=Ce_d9-2c7wI
May 25, 2015 | John Deere Garden
Where can I find a belt for my mower LA 175 John Deere mower
Your local John Deerer dealer or online at a place like
John Deere Parts Online Discount Store Green Farm Parts
Drive belt GX20006
Deck Belt GX31395
May 11, 2015 | John Deere Garden
John Deere La175 Battery doesn't charge while mowing. After I mow for an hour or so and turn tractor off, it won't start. When I put the charger on it for a second or two, it turns over and runs....
I had the same problem. My LA 175 mowere deck would not engage and I figured out that the battery was not sending the sufficient 12volts to the mower deck to run the mower. I replaced the battery and that fixed the problem only to reveal the original problem. Within 2 hours of mowing the battery again died. I replaced the voltage regulator and that didnt help. I need suggestions on where to go from here please. Anybody?
Apr 22, 2012 | Garden
I am burning up deck belts on a 2 year old John Deere LA 105 mower
make sure the pulleys are free the check the arbor brakes
Apr 03, 2012 | John Deere Garden
JOHN DEERE LA 175... TWO FRONT TIRE ARE NOT TRACKING
John Deere allows up to two and a half inches of tow in on the front wheels,to them this is normal.An adjustable steering rod is available but is not covered under warranty,it's up to you whether or not you need to install it,i suggest that you do.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a 21 year old john deere 175 hydro lawn tractor with a 38 inch deck and it needs a new motor and a new swith to engage the lawn mower deck how much is it worth with those being broke ?
Trans 150$.Mower deck 50$.Hood 50$.Fender deck and seat 75$.Front axle and spindles 75$.Electric clutch 40$.This is what you can expect to get if you part it out or you can trade it in for 250$ on a new Deere.
Mar 21, 2010 | Peg Perego John Deere Turf Tractor
The parking brake on my John Deere L118 is stuck in the activated position. Therefore the tractor won't roll. How can I disengage the parking brake?
Usually there is a red handle under the steering colunm that locks the pedal down. You will need to depress the brake as you push down on the red handle which should release it.
Oct 11, 2009 | Garden
Hand break on the John Deere LTR 180 is stuck and
To temporarily fix you need to remove brake linkage to trans.If this works you need to get it to the dealer to replace park brake rod.
Mar 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
315 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
