Question about Bernina Activa 130
I have a bernina 135 and when I press the foot pedal, it whirs, but the needle doesn't move. I've turned it off and on but nothing happens.
  • 109 Answers
Check to see if your bobbin winder is on.
Posted on Aug 23, 2010
  • rdibden May 30, 2011
    This was the solution. Thanks a lot.
I have a Bernina Patchwork 140. How do I change the needle to stop in the down position? The sewing manual is no help.
As far as I know, the Patchwork 140 doesn't have a needle stop up/down button. You'll need to use the hand wheel to bring the needle up or down, as needed. The Bernina machines that have a needle stop up/down button have this button below the LCD screen. (On those machines, it's usually the left-most button below the LCD.) I suspect the index giving a page number for the Needle Stop Up/Down button is a artifact of using the same index for multiple machines.
The manual for the Patchwork 140 is available at Manuals Lib here: https://www.manualslib.com/manual/1002243/Bernina-Activa-131.html . The Bernina 135 has the needle stop up/down button. See https://www.bernina.com/en-US/Support-US/Machines/BERNINA-activa/BERNINA-activa-135 . The manual for this model is https://www.bernina.com/getdoc/90f75840-2b12-4f46-88f2-76f09e35d8d4/030529-52-04_0303_a135-a145_EN .
I hope this helps.
Jul 31, 2017 | Bernina Sewing Machines
Cant get benina 830 to turn on
take it in for a service
could be foot pedal problem or motor problem
Dec 16, 2016 | Bernina Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Benina foot pedal doesn't work
type in browser sewing machine parts in panama central america & see what comes up
or if you have a phone directory check for sewing machine shop & see if they can order one
Mar 09, 2012 | Bernina Artista 180
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
255 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
