Question about Troy-Bilt Pony Garden Tiller
Engine surges at idle or any speed - Troy-Bilt Pony Garden Tiller
  • 54 Answers
That is called hunting and can be caused by various things. The governor controls the engine speed. Is the lever and link/spring correct. Carb in good shape? Spark plug clean and gapped? Fresh fuel or was there old fuel in it?
Posted on Feb 01, 2011
Ford escort 2l engine surges, changes rpm at idle.
sounds like it could be the idle speed control valve
Mar 31, 2014 | 1995 Ford Escort
I have a 99 civic 4 door and the engine surges at idle
hot engine or cold, or both???????????????????
surging or hunting idle is complex but for sure the ECU has lost control of idle speed , there are 2 macro reasons, (vast causes)
1: ISC is stuck (in non SAE terms, the idle speed control valve ) is stuck.
2: engine is missing cause the ISC to GO NUTS trying to control
idle and can not.. the 50 reasons, , have list ask.
we do tests to find out if either or both the above are bad.
do you want tests, or guessing>???
Jan 22, 2014 | 1999 Honda Civic
21 INCH YARDMAN IDLE PROBLEM
If it's a constant speed engine with no adjustement for idle or a variable speed engine with no adjustement screw for idle , then it needs a carburator overhaull . If not adjust the idle scew , engine hot .
Aug 29, 2012 | Garden
Engine is surging when in idle
Sounds like the low speed idle circuit is clogged or the inlet needle tip is clogged in the carb. About the only way to clean these is disassembly.
May 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine surges 100rpm?
Here is the common cause of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Jun 14, 2009 | 2002 Chevrolet Cavalier Coupe
At idle engine surge's up and down usually a few hundred RPM's
DS THIS PROCEDURE
Here are some of the causes of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
May 04, 2009 | 1998 Honda Civic
Rough idle / engine surges until power is applied
Sounds like a possible vaccume hose leak?
Feb 07, 2009 | 1997 Chevrolet Astro
Dodge ram 1500 engine rpms surge at freeway speed
those sensors could cause the issue, clean the MAF 1st, also clean the idle system using the following procedure, the IAC can cause cruise surge. I use this to cure these problems all the time.
Here is the most common cause of surges and stalls and low idle, it is the idle speed control air-bypass valve (IAC) and throttle valve, they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Jan 13, 2009 | 2001 Dodge Ram 2500 Truck
When motor is at idle speed it surges
Try a simple test. It is ok to run the pump without water for a short time. Check idle speed without water in system to see if enginet surges. If it does not surge, then most likely the unloader/ pressure valve is causing the engine to surge when in the unloaded state. Life of unloader /pressure valve is shortened by letting system bypass for long periods of time. Enjoy
Nov 22, 2008 | Garden
Troy-Bilt Pony Garden Tiller Logo
918 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
