Question about JVC AV-27S33 27" TV
When I do an autoscan to program channels, it will program channels 1 to 48 but will not tune the higher channels even though they are there. Is there a special setting/
  • 4,889 Answers
It sounds like thats the maximum number of channels it can tune or you are probably scanning either analog/digital channels only. Is the model number that you have listed correct?
Posted on Aug 22, 2010
Finds no channels on autoscan, even though it found channels a few days ago in another location & another tv finds them in current location connected to the same antenna. Has a part gone bad?
Has the input source been set back to Antenna or TV tuner? Click on the Menu button on the remote and select input and check that it the correct source is selected
Jul 04, 2016 | Televison & Video
Tune nec flat screen tv
what is your input device , ANTENNA if so then you do an autoscan for channels thru the mainmenu
Dec 01, 2015 | NEC Televison & Video
Is this model digital or do I need a top box set
Ian a model number and the make / Manufacturer would be helpful
If you use the select source on the remote control if it displays DTV as a source then it should do digital once you tune the television in - you may have a channel autoscan option in the menu options most likely and you may even see it scan for DTV channels !
Dec 11, 2014 | Televison & Video
Why won't Dynex DX-RCO1A-12 pick up all the channels I should be seeing when I do autoscan..I use a local cable service
You may be required to have a cable box depending on your provider to get higher channels. Contact your service provider for assistance.
Jul 30, 2014 | Dynex Televison & Video
KDL-40V3000 program not tuning
if possable retune with a known working connection ie at the house next door
this will rule out your own setup and may save you time / money in the long run
May 15, 2012 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia Digital TV won't tune Channels 350 and 350, can't manual tune wither as it will only accept 2 digit numbers, even though it tunes 201 ...
These numbers are the LCN (Logical Channel Number) assigned by the broadcasters. It will only be at 350 if it is the same channel from a different transmitter. You need to know the 'channel' of the frequency to manually tune it in. You are talking about the program number not the channel (frequency), a common mistake. i.e ABC in Sydney is transmitted on CH12 (226.5Mhz) and the LCN's for each program are 2,21,22,23,24,201 & 201. If your antenna also picks up the signals from the Kings Cross transmitter ABC is CH30 (543.5Mhz), as these are later in the spectrum they are put in the LCN list starting at 350.
May 10, 2011 | Televison & Video
How do I tune in channels on this TV
if you hook to cable. first you need to go program ang scan the autoscan first in order to change the channel.
May 09, 2010 | Sony BRAVIA KDL-32V2000 32 in. LCD...
How do i tune in a channel
Go to menu and select/autoscan, then if autoscan can't tuned then select manual.
Hope it may help you;
Regards;
VOTIT
Jan 02, 2009 | Philips Televison & Video
We have a sharp lcd tv c/w built freeview,the last couple of weeks it keeps losing just 1 channel ie bbc1 or itv1 every other channel is fine if we retune the tv everything goes back to normal, is it the...
no problem occur on your set but the only problem is you can not lock the fine tuning (in manual procedure) but is it better to set the program to AUTOSCAN OR AUTO PROGRAM and authomatically tune and save to the memory all the program channel
Apr 29, 2008 | Televison & Video
JVC AV-27S33 27" TV Logo
77 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
