What's the easy way to connect speaker wires, I have 7.1 and lots of wires going inside the wall and ceiling, hard to find out which speaker is which?
  • 158 Answers
A wire is only a medium to connect the speakers with the amp/receiver. the thickest of all the wires there belong to the SUBWOOFER .rest all wires can be of the same thickness (gauge).each speaker will have 2 wires (one red ,one black ,usually joined together along its entire length)
the easiest method is the hit &trial method where you connect a pair(of wires) to the receiver output and play.(a speaker should be connected at the other end)
Like this select different speakers with different receiver outputs and connect .
i hope this solves your problem.
Posted on May 04, 2008
  • Sumeet Sodhi Jun 02, 2008
    YOU SEEM TO HAVE FORGOTTEN TO RATE ME .
Want to add external speakers that are mounted in my ceiling. They are a good quality household speakers
How do I Connect Multiple Speakers to my HiFi Amplifier
geoffthegreygeek.com/connecting-multiple-speakers-to-amplifier/
Understand connecting multiple speakers to your hifi. ... In a home theatre amplifier with surround sound, there may be 5, 6, 9 or 11 amplifiers ..... Two 4 ohms speakers in parallel totals 2 ohms, not good for an amp designed for 4 ohms or more. .... I have 6mounted ceiling speakers and I want the same sound on all of them.
Home Audio Installation: Install a Whole-House Audio System
www.familyhandyman.com > Skills > Electrical
New high-tech components make it easier than ever to install your own ... what to buy and show you how to run the wires and mount the speakers and controls. The rest is simple plug-in hookups. ... Run wire and install speakers and distribution modules so that you can .... Put it right next to the audio equipment if you want.
In-wall and ceiling speakers buying guide - Crutchfield
www.crutchfield.com/.../home/speakers_inwall.h...
Crutchfield CorporationHome Speakers / ... In-wall and in-ceiling speakers have become some of our best-selling ... about audio quality, and are also a great solution for folks who don't want to... But instead of being attached to a cabinet, it's mounted in a frame and set ...They're a great way to add background music to small or awkward spaces, ...
Dec 28, 2015 | Audio Players & Recorders
How to wire in an on-off switch for ceiling light from power source going to living room.
Pretty easy if you can get the wires from the existing wall outlet. Just run a wire from existing outlet to the where you want the new light. Install inside an approved ceiling electrical outlet box and then run another wire to where you want the switch or switches. If you go to home depot or the library you can look at the books with diagrams on how to wire it. You can skip the wall switch if you use a light with a pull chain.
Sep 20, 2014 | Electric Electrical Supplies
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Wiring heater, vent, light with 12/2 and 12/3 from switch to unit. email: lfranklin5@charter.net
I wish we had more information to go on here.
1) You have 2 cables to to the Heat-Vent-Light
One cable is 12-3 and 1 cable is 12-3
2) That's where it's gets fuzzy.
What color wires are on HentVentLight?
Is power at the ceiling box or at the wall box?
What other wires are inside the wall box?
What kind of switch are you installing?
3) With that number of wires, it sounds like power is at ceiling box.
Power would arrive at ceiling box on one cable that has a Hot-black and Neutral-white wire.
4) Start at wall box:
Let's suppose you are installing a wall device that has 3 individual switches, with one switch for each HentVentLight.
The Hot wire from ceiling box would drop down into wall box on a black wire, and this wire connects to brass screw on switch.
Wire going to heater connects to one of the silver screws.
Wire to fan to another silver screw
Wire to light to another silver screw.
5) Work at ceiling box:
Let's suppose your HentVentLight has 4 wires: Black for light, Red for fan, Blue for heater, and White Neutral.
The white neutral connects to Neutral wire as described in #3.
Black, Red and Blue connect to each of the wires that come up from switch.
Add a comment for more free help, and fill in the missing information.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 01, 2011 | Broan-NuTone FAN CONTROL SWITCH
I have constructed a hall for the purpose of meetings. But now there is too much of echoing within the hall. even without loud speakers. With loud speakers, it gets worse. How solve this problem of echoing
Excessive room echo is caused primarily by two things - hard surfaces and high ceilings. The worst materials are glass, marble and concrete block. Next to this is drywall. The more hard surfaces you have, the worse the echo will be. For example an entirely drywall room is much worse than one with drywall walls and an acoustic tile ceiling. The sound simply bounces from the back wall, to the front, to the ceiling, to the floor, back to the walls, floor, ceiling and so on. The solution of course is to reduce the amount of hard surface area.You need to coat the wall with some sort of acoustical wall treatment. Carpet on the walls will work or you can purchase materials for that purpose. How much to install and how much area to cover will require experimentation. There are many choices and this is just one.
http://www.acousticalsolutions.com/
An online search will provide many options. Search will the term "Acoustical Wall Treatment"
Oct 08, 2010 | Hammering
I put up a new ceiling fixure which is controlled by a wall switch. The light now won't swirch off....... I attached the fixture's 2 black wires to the black and the black with a white stripe wire in the...
One of those cables in the ceiling is a power cable from the electrical panel . the other is a wire to the wall switch. if you have a meter then you can connect them correctly .. BUT ,, basic connection would be .. the two black house wires together ,, then a white wire to each of the fan wires .. that puts the fan/light on the switch control.
To be totally correct the white power wire should connect to the white fan unit wire.
Nov 16, 2009 | Westwind Classic Hugger Polished Brass 52"...
Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
May 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Home speakers
1st of all i would take a multimeter and test each wire to make sure you have a connection after this i would use any amplifier connecting 2 speakers at a time locating each one and then label the cables then from there buy a suited amplifier for your needs and away you go
Sep 11, 2008 | Wave Audio CS801 Speaker
Converting 2 channel amplifier to 2.1 amplifier
it is not availlable to do such convertion.
Jul 05, 2008 | Audio Players & Recorders
Installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Nov 17, 2007 | Dryers
 Grubhead
Grubhead
