Question about Kenmore 44102 Front Load Washer
Kenmore front load washer model 970-C41052-00 has what looks like grease spots on the laundry after the cycle has finished the machine is aprox 7 years old.
  • 3 Answers
SOURCE: Kenmore frontload clothes washer (Canadaian
Wow! Mine also looks just like this - a large hole in the back of the spin basket. Same timing too - about 59 months for me.  All of a sudden, during the spin cycle we heard a huge bang,...and then the banging continued. There is no way I'm spending $200 + labor to get his fixed. If the part is only going to last 5 years, then I may as well go ahead and get a new washer....and it definitely won't be this make or model!
Posted on Dec 20, 2009
yalmer
  • 549 Answers
SOURCE: kenmore front load washer Model 970-C40042-00
Click this link.
They will have a manual for you.
Posted on Apr 02, 2008
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Posted on Aug 30, 2008
SOURCE: kenmore front load washer 970-c45072-00
We had the same problem and this website solved it for us. The child lock is on when the lock symbol light in the lower right of the panel is on. The machine will not start with the light on. If you press the Option and Select buttons together (there is a lock symbol with a line to the two buttons), the lock symbol light will switch between on and off. When it's off, the machine can start. None of this was in the "Use and Care Guide," maybe we lost our manual. But thanks for helping to solve the problem!
Posted on Jun 10, 2009
SOURCE: we have a kenmore elite washer mod. 970-c40062-00
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Posted on Mar 24, 2010
Greese spots on laundry from my G.E. washer
need these questions answered 1st in order to address your issue. are the spots black grease as in the type of grease used to lubricate the drum mechanism? also, did you purchase the washer new or used and have you ever had it serviced?
Aug 24, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Gets stuck in mid cycle
you need a new timer mechanism
May 23, 2010 | Kenmore Front Load Washer
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
I get oil/grease spots on my laundry ffrom my
You probably have a bad seal on the back of the drum, as that bearing is the only source of grease near your clothes. Good luck.
Jan 03, 2010 | Frigidaire GLTF1670A Front Load Washer
Kenmore 970-C41062-00 Spin cycle, belt keeps coming off
sounds as if yo umay have a bad rear bearing, and the off balance of it is "throwing " the belt. magor repair, and would ck with manufacture, for possible part warr
Mar 18, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
I have a Kenmore Elite front load washer model # 970-C41072-00.In the last few days , particularly on the spin cycle , there is alot of noise coming from the machine as though something is loose ...almost...
first look inside the spin tub to see if a nail, screw, or underwire is stuck and scraping the outer tub when in spin.
Remove the lower front panel and see what you can see.
You probably will have to remove the unit from under the counter.
Jul 16, 2008 | Kenmore Washing Machines
Black spots on white laundry
is the washer noisey when spinning? If so its probable that the main bearings are worn, & losing the original grease into the wash tub. At 10-14 yrs old its probably not woth fixing (assuming parts are still available)
Oct 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 44102 Front Load Washer Logo
557 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
