Question about Genie Company Health & Beauty
I have a GX-9000 Genie Garage Door Opener. The receiver has been taken out by lightning. I purchased a GIRUD-1T Receiver Kit. My questions are: Do I runs the 24 VAC from the transformer to the receiver and then on to the operator, or just to the receiver? My new receiver has 3 terminals marked power, common and wallbutton terminal. Which of these goes to terminals 1,2,3, and 4 on the operator? Finally, will G2T-1 transmitters work with this receiver?
SOURCE: Garage door opener transmitter/receiver compatibility
Press and hold the homelink button and wait till the red light flashes slowly,but don't release it. Now hold a working remote 3 inches away,press the remote button and hold it.When the red Homelink buttom fllashes quickly, release both buttons. Now go to the opener and push the learn button. Now go back to your car and press and hold the Homelink button. You will see the lights on your opener flash. Now your Homelink button should operate your garage door.
Posted on Feb 09, 2009
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
  • 3197 Answers
SOURCE: I've got a Sears/Craftsman 1/2 HP garage door
If you have the wall control with 3 buttons one of them is the lock button. It is not on the side. If you have it and the light in the wall control is flashing, press and hold the button with the lock icon for 3 seconds and release. If that is not the situation your receiver is bad. The receiver is inside the motor unit and is part of the logic board.
Posted on Dec 30, 2009
  • 43501 Answers
SOURCE: Why two 24 Vac on aprilaire 700's control unit?
Okay, I looked up the installation manual online to see exactly what you are working with.
Yes the R anc C need to be hooked to the transformer supplied with the unit. The primary 120v side needs to be hooked into the power coming into the furnace. this can easily be done were the L and N get hooked into your furnace or circuit board on the furnace. This will provide the contiuous power to the unit. Preferably you will hook this after the door switch of the furnace so that you will kill the power toit if you take the blower door off.
The ODT terminals are for the outdoor sensor if you want to hook that up it will vary the humidiy in your home according to the outdoor temperature then.
Now the W/G and Cf terminals. If you have 24v coming from the HUM terminals of your furnace you DO NOT need a second transformer. You must check your furnace manual or check the voltage to them with the furnace blower energized. The HUM terminals will only have power to them when the blower should be running.
If the HUM terminals are 120v then you need to get another transformer and hook up the primary side to the HUM terminals so it is powered only when the the blower is running. Hook the secondary side to the W/G and Cf terminals.
So bottom line is that you need to figure out what voltage your furnace is giving to the HUM terminals and then go from there. Some times the EAC terminals or the ACC terminals will be 24v on the furnace board. Either of them could be used also, as they are only energized when the blower is running also.
Posted on Jan 25, 2010
  • 407 Answers
SOURCE: I have to replace the
All the terminals are connected together so it won't matter which terminal you use, just as long as you have the Herm, Com, and Fan wires correct. Hope this helps!
Posted on Sep 28, 2010
I cannot program my receiver Genie ACSR3 to work with a remote Genie GITR-3
check age difference, every so often the codes change and older parts will not work with newer parts
Nov 03, 2014 | Building Materials
Garage doors opens on its own, after being close for hours
Someone in your neighborhood may have the same garage door opener that you have and sharing the same code. Change your garage door opener code or buy a Genie Code Scrambler.
Apr 05, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
I have Genie Screw Drive garage opener...the problem is the remote is not opening the door...the wall unit will open.... changed the battery...not working...the unit is about 10 years
If you have only one remote it is impossible to determine if it is that or the receiver that is bad. The wall unit doesn't use the receiver so that doesn't tell you anything. No good answer.
Nov 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
I had a lightening strike at my home. Since then, the garage door does not function with wall switch or remotes. when i press the switch, light comes ON on the door opener and i hear a click but nothing...
Well, I don't think that disconnecting the garage door from the garage door opener would affect function.
The lightning strike could have destroyed the circuitry inside the garage door opener, seeing that it won't operate with the wall switch or remotes.
It's likely that a board was fried by the lightning which would render the garage door inoperable.
Aug 08, 2010 | liftmaster Chamberlain Garage Door Opener...
Genie Screwdriver, garage remotes won't work, batteries are fine.
Your receiver has quit working. A call to your local Genie dealer should get you back in business.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie remotes stopped working
The receiver can go bad and that would stop all remotes from working. The wall control would still work because it does not use the receiver.
Sep 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Health & Beauty Logo
105 people viewed this question
Top Genie Company Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Genie Company Health and Beauty Expert? Answer questions, earn points and help others
