Question about Refrigerators
ED5chqxkt03 - We can't locate where the water filter is located in the fridge...can you help
  • 54 Answers
SOURCE: water leaks underneath fridg when I try to dispense water
Call ge 800GECARES there are factory trained tech
Posted on Jul 03, 2008
SOURCE: water filter location
underneath the fridge side it is a circle on the bottom
Posted on Aug 23, 2008
  • 62 Answers
SOURCE: Where is the water filter and how do I change it out?
The Roper ref is basically a Whirlpool ref. The filter on a side by side unit usually is down the botton in the grille area slightly to the left of the center post. The grille will have a round hole opening, and filter should be there. The other place is in the ref section at the top rear right hand corner. The other possibility is that the unit may NOT have a filter. Not all units had them. If the unit is older than 5 yrs or so, ir propably did not have one and thus the external filter your parents were using. Or your parents took the filter out and the opening is empty. These units have an automatic by pass in them so they can be used without a filter or that an external one could be used.
Posted on Aug 31, 2008
mark_37388
  • 100 Answers
SOURCE: Need to replace water filter, can't locate where.
Look down at the grill at the bottom of the frig under the freezer door will be a section of the grill the looks like the grill but has a ring around it twist it counter clock wise and the filter will twist out and the grill front slide off the old filter on to the new filter good luck.
Posted on Apr 02, 2009
localwonder
  • 6784 Answers
SOURCE: can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
Posted on May 23, 2009
Where is the filter located in this model? Thank you!
Fridges with ice and water facilities have filters either inside the food compartment or at the rear of the fridge or on the water supply line from the tap. Look for a canister shaped part with hoses going to and from it or a canister shaped cover which unscrews inside the food compartment. Make sure you turn the water supply off at the tap before you take the filter out. The tap will be inside a cupboard adjacent the fridge or perhaps outside on a wall near where the hose goes through to the fridge. If you have the make and model, look them up on the internet under the manufacturers name. Most companies will have online instructions on filter changes.
Dec 09, 2015 | Refrigerators
Water on inside of fridge does not work water spout is located on the left side wall inside the fridge. I push the button, and no water
There is few things that could be the problem. 1. filter is clogged or not seated all the way. 2.Bad filter holder, check valve sticking. 3. Bad water valve. I hope this helps.
Aug 24, 2011 | Maytag Refrigerators
Hello. please tell me where the water filter is located? Thank you
they don't have filters in the machine, if you have a filter look in the basement,find the water feed line going to the fridge and see if the plumber installed a filter.if he didn't shut off the water valve going to the fridge,cut the water line and install a filter.you'll need to buy a filter and a couple of connectors to connect the filter to the water line.hope this helps.
May 01, 2011 | Sub-Zero 690 Side by Side Refrigerator
Where is the water filter located on a kitchenaid ksrp25qdwh00
This particular water filter is known as a ``in line water filter`` and is located at the BOTTOM of the fridge at the LEFT hand side. located in the grill at the bottom. first you must remove the filter cap and then It simply twists out for easy replacement. part number for the water filter is 2255519. and should be replaced based on a 6 month period or the amount of water filtered. hope this helps
Thanks
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Where is the water filter located?
Look at the bottom of the fridge in the grille for a round trimpiece that is removeable.
It is behind the twist - off trimpiece.
SEE THE DIAGRAM/LOCATION HERE
SEE THE FILTER HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2009 | Kenmore Refrigerators
Location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Jul 22, 2009 | Refrigerators
Water not coming out
Without knowing the model # filter is usually located on bottom of fridge in grill. When you depress the lever listen for the water valve in back of fridge to click on if not you may need a new water valve. What is the age and model # of fridge?
Nov 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Poor tasting Ice
There could be a filter installed. The filter usually looks like a long tube about 6-10" long and about 1-3" round.
Try to located the water line. This will be either a copper or plastic tube about 1/4" diameter and will be going into your fridge from the back of the unit.
The filter could also be located at the point of where the water is being supplied from. Possibly under your sink or it could of been tapped into another line in the basement if you have one.
If you located a filter, you will be able to see if you would be able to remove it and replace it on your own. It usually takes a couple of wrenches, but MAKE SURE YOU SHUT THE WATER SUPPLY OFF FIRST before attempting to remove it or else you might have to go swimming. (Actually it's a small tube, so not a lot of water will come out, but you still need to shut off the water supply to the fridge. Then you can bring the old filter into your local hardware store and get a replacement.
I hope this helps.
Good luck.
Mac =)
Mar 20, 2008 | Freezers
WATER FILTER
All of the cabinets I have worked on have had external water filters, so unless yours is really special you will normally find the water filter located behind the fridge freezer in the incoming water supply line (typically 4 - 6 inches long 2 inches diameter). Some cabinets now have a timer to indicate a long duration, none that i have come across monitor water quality. Hope this helps.
Mar 09, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
