Question about Simmons 511070 4x32 22 MAG Riflescope - Glossy Black
The elevation adjustment screw will not turn on a simmons 22 MAG mini 4x28. Which way should it turn to raise point of impact? Counterclockwise or Clockwise?
    President:
  • 2,702 Answers
All scopes are marked for up or down with a " u or d" or a
"+ or -" for up and down
just dont forse the turret screws or you will bust the scope
Posted on Aug 28, 2010
Scope insternal adjustments do not do anything. This is the second new scope I have had this problem with. I have borescoped the rifle and no change in either windage or elevation screws over entire...
One of the things about bore sighting is there is no shock to the scope. They are meant to have some shock that goes along with an adjustment. Try smaller adjustments and tap the tube of the scope with a screw driver handle after every adjustment. Not so hard you dent it but hard enough to get stuff moving. Hope this Helps FixYa up.
Aug 24, 2011 | Simmons 511070 4x32 22 MAG Riflescope -...
Which direction do you turn windage and elevation
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 22, 2011 | Tasco 22 Riflescope
My bsa sweet 17 6-18 is shooting about 2 inches high at 100 yards. on the adjustment turret it has an arrow that shows which way to turn for up. What is moving up? the point of impact relative to the...
Jun 02, 2011 | Bsa Optics Sweet 17 Target Riflescope...
When I turn the turrets they go in the reverse direction, WHY
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Thats just the way it works. Point your right index finger at a spot on the wall, and sight down your finger like looking at sights, then take your left index finger and pretend it is a horizontal cross hair above your shooting finger, then raise your left finger a set amount above the right, then move your hands back to the shooting position not changing the distance in between, using your left finger now as the sight. You will see your shooting finger is now pointing lower than before. This is now the new point of impact, lower not higher. Hope this is clear as mud and helps Fix Ya up.
Dec 30, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
How do I adjust the reticle for a Simmons Mag 4X32 scope. The reticle is not straight up and down and level parallel.
the reticle should be level if its not you need to turn the scope body round in its mounts till it is level and then nip the scope caps up
Sep 06, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
Have no idea how to set up the sight on my air gun
I don't have this particular model. Chances are, those are not "knobs" but caps. Remove the caps as you would remove the caps from a pill bottle. Underneath, you should find the adjustment dials for windage and elevation,
You can download a generic Simmons scope manual here:
http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Apr 04, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
Need a manual for a simmons rifle scope model # 1022
When you click on "customer service" on the simmonsoptics.com website, it takes you to the Bushnell customer service web page.
The number for customer service that is given is:
1-888-276-5945
The customer service rep. told me to "go to the Simmons web page".
Which, of course, takes me back to the Bushnell web page. It's a circular race track.......
In my opinion, Simmons/Bushnell has lousy customer service.
I bought a 2nd hand Simmons 3-9X50 scope (model #800479) that needed the screw on caps for the reticle adjustment screws. A small request, I thought.....one that should be easily remedied by calling Simmons/Bushnell customer support.
No dice. Customer support told me to spend $15 to send them the scope, and then they "will have to look around and find something that will fit."
Oh really??? Doesn't Simmons/Bushnell already KNOW the sizes of the parts they have?
Just send me the damn caps. They will cost Simmon/Bushnell no more than a buck apiece.
Then I asked for a user manual for said scope. No dice. The customer support lady told me to find the manual on the Simmons web page.
The Simmons web page doesn't provide user manuals online.
Their customer support needs a lot of improvement.
May 09, 2009 | MAG Simmons 22Mag Rifle Scope 4X 32...
Windage and elevation not working barska 8-32*50mm
I doubt if there is anything wrong with your scope.
The Baraska model A10810 Reticle adjustments are 1/8 ( 1/8 inch) MOA (minute of angle).
For instance, Look at the top turret (The ELEVATION Adjustment Knob). You will see that there are little vertical 'hashmarks' all the way around the knob starting with a '0' then a series of the verticle hashmarks, then a '1' and another series of the marks, then a '2' and so on. YOUR scope will have 8 of those vertical 'hashmarks' between each 'number'. These little 'hashmarks are referred to as 'Clicks' or 'Minute of Angle' adjustments.
Now imagine that you are set up on the 100 yard line and you have fired a round at your target, say a one inch diameter dot or any size for that matter, and the bullet strike was one (1) inch LOW and two (2) inches to the RIGHT and of course you now want your next round to impact in the target dot.
To bring your bullets point of impact UP to coincide with your point of aim (you have your 'crosshairs or RETICLES centered on the dot), you will be turning the TOP adjustment knob CLOCKWISE, ONE 'click' at a time. EACH one of those 'Clicks' will actually move the horizontal Reticle UP (Elevation) or DOWN 1/8 of an inch at a time. If the bullets point of impact was 1 inch LOW, you would need to turn the adjustment knob clockwise Eight (8) clicks which will equal ONE (1) inch.
Now you must adjust the knob on the RIGHT side of the scope. This one is the WINDAGE Adjustment knob which controls the VERTICAL Reticle and moves the point of impact Right or Left. This knob will also have the 'hashmark' increments around its perimeter and like the Elevation knob each 'Click' will move the Reticle 1/8 of an inch but in this case the Reticle and point of impact moves Right or Left.
Remember the bullets point of impact was 2 inches to the RIGHT. This means you must adjust the Reticle or point of impact to the LEFT so that your point of impact will coincide with your point of aim and will be in the target dot. Turn the adjustment knob COUNTER CLOCKWISE Sixteen (16) Clicks. Keeping your POINT of AIM (crosshairs centered on the dot), your next round should be inside the dot and you can then fine tune it from there.
As you can see from this example, the Reticle (crosshairs)and point of impact does not travel very far at all inside your scope at the 100 yard distance so it is not hard to imagine that you thought they were not adjusting to get you on target, when in fact they WERE adjusting, but in tiny increments.
Now, as you create more distance between you and your target, these 'tiny' increments and point of impact will be larger as your distance increases. For example, at 200 YARDS each 'click' will move your Point Of Impact 1/4 of an inch right,left,up, or down. So if your bullet point of impact was one (1) inch low from the 200 yd line you would adjust your Elevation Reticle 4 Clicks to raise your point of impact in order to be on target. At the 300 yd line each Click will adjust the point of impact up,down,right or left, ONE (1) inch.
If you wish, I would be happy to walk you through the 'ZEROing In' of your scope and rifle even if you do not have a Zero Bore Scope. With-in about 9 rounds you can be hitting where you are aiming instead of 'chasing' bullet holes all over the paper.
If you are interested, respond back and I will be glad to assist you. Enjoy. :)
Apr 07, 2009 | Optics
Simmons 511070 4x32 22 MAG Riflescope - Glossy Black Logo
267 people viewed this question
Top Simmons Optics Experts
Mark Campeau
Level 1 Expert
John Hong
John Hong
Ted Maxwell
Are you a Simmons Optic Expert? Answer questions, earn points and help others
