Question about IBM USB Portable Diskette Drive (05K9276) External Floppy Drive
USB Portable Diskette Drive External Floppy Drive will not format - actually has changeds the formatting style and cannot be read by another device
5 Suggested Answers
  • 48 Answers
SOURCE: nexxtech usb external floppy won't eject
Look for a very small round hole in the plastic "cabinet" near the media slot (on one side) and gently poke a small paper clip (unbent, of course, first) in to manually eject the disk.
Posted on Apr 07, 2009
Kuwagata
  • 181 Answers
SOURCE: I have a USB portable diskette external floppy
Try different and empty disk, then format it, when you can open it after you format it, then your first disk is damaged.
If still persist, then clean the drive using floppy drive cleaner, it should work.
Posted on Oct 24, 2009
  • 245 Answers
SOURCE: Your Ad says: Free tech support for IBM USB
Hi
If you'll ask the question,I'll try and help you out.
Bob
Posted on Aug 23, 2010
bronk50
  • 27725 Answers
SOURCE: I have a Teac USB
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Apr 28, 2011
NEED"S DRAIVER FOR IBM USB Portable Diskette Drive
Any "plug-and-play" device with a USB interface should be supported by Windows XP/Vista/7/8. Try it!
Feb 21, 2013 | IBM USB Portable Diskette Drive (05K9276)...
Free download of Drive Portable Diskette Drive-N533 for Window 7
May 05, 2012 | IBM USB Portable Diskette Drive (05K9276)...
Ibm portable disk with iMAC
You should be able to use it, just plug it in then open up disk utility which can be found in applications and then utilities. Once open you can format whatever way you require.
Jan 27, 2012 | IBM USB Portable Diskette Drive (05K9276)...
I have a usb portable diskette drive that says compatabible upto windows 98 I have windows 7 can I download drivers for it?
If it won't plug and play then your basically out of luck. That is a very old device. If you still need to access floppy's i would purchase a newer device or have an internal floppy installed.
thank you,
Lee
Jul 26, 2011 | IBM USB Portable Diskette Drive (05K9276)...
Every floppy I put in the message comes up to format it but they won't format
are you sure that write protect is not on if it is you have to slide the switch to the write enabled
Jan 02, 2011 | IBM USB Portable Diskette Drive (05K9276)...
Need for IBM USB Portable Diskette Driver for windows 7
Nov 12, 2010 | IBM USB Portable Diskette Drive (05K9276)...
I have an IBM External USB Floppy Disk Drive that I'm trying to use to access some old files on floppies. Do I need special software to be able to use this? Or...can you tell me how to make it work? I'm...
this device is plug and play does not need any type of configuration basically you plug the device and the server (PC) would usually recognize it as the "A" unit
Aug 16, 2010 | IBM USB Portable Diskette Drive (05K9276)...
I have a USB portable diskette external floppy drive. It is new. It is supposed to work by simply plugging the in teh usb. When I try to use it, it always tells me to format the disk. i of course, do not...
Oct 17, 2009 | IBM USB Portable Diskette Drive (05K9276)...
IBM USB Portable Diskette Drive (05K9276) External Floppy Drive Logo
71 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
