Question about Kenmore 24032\24036 Top Load Washer
Lid safety on off switch is broken - Kenmore 24032\24036 Top Load Washer
  • Kenmore Master
  • 43,501 Answers
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 22, 2010
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Washing still wet at the end of the cycle
If the machine is a top loading washer a common cause for this problem is the safety switch in the top lid door. If the switch fails to close because the lid is up or switch failure then the washer will not go into the spin cycle. A projection on the top lid enters a hole allowing the closed lid to activate the safety switch.
On older models the switch activation produces a distinctive click. A small dry wood stick could be used to gently push in to the hole while listening for the distinct click of the switch.
  • Than carefully closing the lid should produce the same sound. If no sound is produced as when manually bypassing would indicate that the tab on the lid or the switch position has been out of location or the switch is broken
If the tab has broken off the lid or the switch is either out of position or failed the parts will need to be replaced.
Nov 21, 2015 | Washing Machines
LID CLOSED STILL SHOP LID AS AN ERROR
Looking from the back of the 8650 counter with the lid open, there is a safety switch on the left side. It is either not pressed in when the lid is closed or it is broken. To test, take the two wires from that switch and connect them together. That will by pass the switch and allow the machine to work. Good luck.
May 08, 2014 | Talaris EV8650
Washer will not spin dry
see the causes:
t doesn't pump or spin
frozen pulley or broken belt replace+lid switch open or defective replace
It pumps, but doesn't spin
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, the basket is worn.
It spins only with the lid closed
for safety, only sping with the lid closed.
Jun 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer not spinning at all. But all else works
the lid switch is most likely broken (washers will not spin out if the lid switch is broken
for safety reasons). Hope this helps.
Jun 08, 2011 | Kitchen Ranges
Lid will not engage safety switch , closing lid does not engage safety switch , i have to wedge something in it
Either the pin on the lid has broken, or the switch mounting bracket has broke or the screws losened and the pin cannot push the switch enough. If the switch is mis-positioned, you'll have to open the washer top and check out the switch mounting. Goodluck< Macgivor
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The lid switch on my kenmore 70 series has broken off. The wires are still attached, but the plastic unit is no longer connected to the underside of the machine top. I need to drain the machine somehow in...
There are two wires attached to the lid switch, just connect them together and the machine will work as normal. Please take care not to open the lid while it is operating. This switch is a safety cutout.
Nov 18, 2009 | Freezers
Need to know about safety switch on washer lid
First, this machine has an electronic motor. Check to see if belt is broken. If not then unplug for 2 minutes, plug back in and open and close lid 7 times slowly. This will reset motor. A common problem with this machine. I dont think it is the magnetic lid switch.
Jun 15, 2009 | GE WBSR3140DW Top Load Washer
Possible lid switch stopping basket from spinning
Lid switch is safety mechanism that cuts off power to motor when lid is open. If it is broken or faulty you will not get power to motor during spin. Hope this helps!
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
