Question about LG Cell Phones
HOW TO DO FRACTIONS ON CELL PHONE - LG Cell Phones
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
Which is more precise, fractions or decimals??
Fractions can be more precise than decimals. For example: 1/3 can not be expressed exactly as a decimal. .33333333333333333333333333333333333333333... is only an approximation.
Some numbers cannot be expressed precisely as either a fraction or a decimal. pi is an example.
Jan 04, 2017 | Homework
My TI 84 won't convert my imaginary numbers to fractions. I typed in 1/(1+i) and it won't convert the answer to fraction form. It keeps saying Error Data Type
The TI-84 works with real fractions. It will not convert complex numbers to fractions.
You can convert the real and imaginary components to fractions separately. For your example, 1/(1+i) is .5-.5i. Converting .5 and -.5 to fractions, you get 1/2 + (1/2)i.
Sep 15, 2011 | Texas Instruments TI-84 Plus Calculator
I CANT GET MYCALCULATOR TO DO FRACTIONS CAN YOU HOPE ME
To configure the calculator to do fractions, set the Input/Output mode to MathIO.
Press [SHIFT][MODE] to open (SetUp) then select [1:MathIO].
After you set it to MathIO, pressing the fraction key will display a fraction template where you can enter numerator and denominator as you would by hand (horizontal fraction bar). Also, the calculator will display results as fractions and radicals whenever possible.
To perform arithmetic operations on fractions use the regular operation keys (x, +, -, /). The calculator will perform the operations and display the results as fractions (whenever possible).
Aug 15, 2011 | Casio fx-300ES Calculator
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
How to convert fractions into equivalent fractions
find the least common denominator between the original fraction into the new fraction.
example, 1/2 to 2/4 to 4/8 to 8/16.
May 19, 2010 | Cycling
Pc draft fractions
if you are using MS Excel, you can type fractions by typing 0 1/2 instead of typing 1/2 only. All fractions must be preceded by 0 (zero).
Regards!
Jul 04, 2009 | Computers & Internet
Fractions
there is a A b/c button. This is the button use to enter fractions. so 4/3 would be entered as 4 |A b/c| 3
If you want to have the answers in fractions as well, then I believe you hit more a few times. And then there should be a display option, in the display option, there should be a b/c. This will show your answers in fractions. Hope it helps
May 05, 2009 | Casio FX-300MS Calculator
How do i display fractions?
to convert decimals to fractions, type the decimal then press "math" and the first one labled >frac
*NOTE* this does not work for huge numbered fractions, like 65453434323/1000000000
Oct 29, 2008 | Texas Instruments TI-84 Plus Silver...
Fractions multiplied by fraction to get fraction
In the CATALOG there is a >Frac command that can be used with parentheses to multiply fractions.
(1/2)(1/3)>Frac
1/6
Jun 18, 2008 | Texas Instruments TI-85 Calculator
Cell Phones Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
