Question about RTO PasLode 900420 Impulse Framing Nailer
Need some help disassembling a paslode 900420 in order to change the molded circuit assembly( part number 900475), the battery contact broke off.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 67 Answers
I can't give any better advice then the manuals you can download from Paslode.com they give you step by step directions.
Posted on Sep 13, 2010
Paslode 350 tell no light
If you have no light at all in the handle and you're sure you have a charged battery, then I would look at the battery contacts - that tool has the contacts molded into a circuit board assembly so if it is not obvious I would take it to a repair center to be diagnosed.
May 07, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Changed the circuit board on a Paslode IM350 and now the fan wont work any Ideas welcome
fan motor could have gone bad, spark unit(little black box in handle) could be bad. one of the three top conections could be loose, or hooked up wrong, battery contacts on end of circuit board assembly could be placed a little off( battery not making contact with circuit mold assembly) pinched one of the wires going to the trigger area, or fan area
Sep 26, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode fan runs half spped and will not fire unless fan motor is unplugged
if your fan motor is ok, which it probably is, it has got to be the spark unit . the spark unit is the brains of the operation. the little black box located in the handle of the tool( the spark unit ) can cause fan to run slow or not at all. its a bit expensive( probably 60-80 dollars) but not that hard to change out. if its the original be careful pulling it out its glued in from the factory.
Sep 24, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun ,fan won't shut off
replace circuit mold assembly or spark unit its probably the spark unit
Jul 08, 2012 | RTO PasLode 900420 Impulse Framing Nailer
I have a paslode cordless framing nailer 900420, just changed the molded circuit board and worked fine, put it away for about 4 weeks when I went to use it again the fan will not come on and will not fire
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Jan 17, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer was working fine then stopped working and there is no led light. i put another battery in but still no green light. Jim
check the battery contacts in the body of the tool for corrosion or bent or broke, also clean the battery contacts with an eraser
Sep 20, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode fires just as you realease the gun from the surface
sounds like the trigger m8 the only way to cure it is to replace the molded circuit assembly 900475. but try cleaning the trigger switch and make sure the spring is seated properly. hope this helps m8
john
Jun 09, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 900420 piece fell out
Be sure to remove the metal nose piece that covers the lockout bar when assembled. It may be stuck to the other half of the gun. Replace the bar and the spring and put the metal nose piece in its position over the lockout bar. At this point the metal nose piece will be on the opposite side. This will allow you to replace the 2 halves carefully so as not to loose the spring.
Apr 23, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 900420 nailer green light cycles doesn't stop???
Sounds like you need a new circut assembly.
Around 40 bucks.
Thanks,
Jeff
Feb 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
212 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
