Question about Sony KLV-S23A10 23 in. LCD HDTV
Sony KLV-S23A10 takes approx 30 minutes to warm up
Hi, I have a Sony KLV-S23A10 and when turning it on there is no picture, only a black screen with a few thin red or blue vertical lines depending on the channel. After about 30 minutes, the picture will suddenly appear and everything works fine.
This of course happend about 1 month after the warrenty ran out. Any ideas on what is wrong and how to fix it?
Thanks!!!
  • breper Nov 04, 2008
    I have same problem. TV takes at least 30 min to turn pic on. HELLLLLP !!!!
  • eagle2t Jan 13, 2009
    I have the same problem, and check with repair shop, they asked for $250. I will try the reset as Raditronics show, then update to all. Thanks
    President:
  • 196 Answers
OFF YOUR TV WITH POWER BOTTON, THEN PRESS IN REMORE CONTROL DISPLAY BOTTON # 5 BOTTONVOL + BOTTON AND POWER BOTTON.( DISPLAY--5--VOL+--POWER)
Posted on Dec 20, 2008
I have a Sony Wega KLV-30HRS3. It powers up ok, but the only thing that comes up is a multitude of coloured vertical lines. The built in graphics still work, ie the Menu page and the channel number in...
Hi there are a few things that could be bad on this TV. the first thing I would check is the T-con board if that's not the problem then the signal board and last the screen itself. If you are planing on doing it yourself you can get parts from www.interliquidparts.com
Jun 02, 2011 | Sony WEGA KLV-30XBR900 30 in. HDTV-Ready...
What is the remote code for this tv Sony KLV-S32lA10
Hello
Programmable code number for DVD/VCR [Sony] is _ 601 (Sony Dream System)
Programmable code for SAT/CABLE is _ 801 (Sony Satellite Receiver)
Above stated both codes are common for [SONY KLV-S19A10 _ KLV-S26A10 - KLV-S23A10 AND KLV-S32A10 compactable]. OK.
Feb 24, 2011 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony KLV-S32A10 LCD TV background light haas dark shade patches on right side of screen.
You either have a malfunctioning LCD controller(T-con) or the panel itself is faulty. The T-con is very inesxpensive and easy to replace but the panel is gonna cost you nearly as much as a new tv. Let me know if you want to give the t-con a shot so that I can guide you to fix it.
Dec 06, 2010 | Sony KLV-S23A10 23 in. LCD HDTV
WHEN I FIRST TURN ON TV ALL I GET IS VERTICAL LINES FOR ABOUT 20 MIN. TO A HALF HOUR... THEN I HAVE A CLEAR PICTURE.
this may be a problem on the 5 volt line in the set, there is a constant 5 volts running through it even when it is off....so long as its plugged in.
There may be condensors that are open on the 5 volt line.. after they warm up they start to function more proper. but being that they are leaky..they are no longer doing thier job of keeping voltage steady until they warm up.
i do not condone this but if you were to open it up , im willing to bet you have a series of swollen or blown condensors that are not doing thier job on the pwb (power supply board) if thats the case its a 30 minute fix for a technician. Id like to discuss this with you further , i do have a couple questions that may help me diagnose this.
Dec 11, 2009 | Sony KLV-S23A10 23 in. LCD HDTV
When first turned on the TV works normally - then the picture disappears and there's nothing but snow. Change channel and the picture appears momentarily and then snow...
Good day sir/maam, the trouble is caused (possibly) by the failure of the IF amplifier system of your TV, it is usually sets of transistors, or an IC that controls the gain of your TV. Have your service repair man check the section fro the tuner stage to the IF stages. chances are the IC is not functioning properly. Hope this helps.
Oct 12, 2009 | Sony KLV-S23A10 23 in. LCD HDTV
From a cold start,power on,screen is all blue with "no signal" in the upper right corner. while still in blue screen mode approx 2 minutes after start a squealing sound starts. about 1 minute later the...
Sounds like a power supply fault due to leaky capacitors(electrolitics).
From cold take the back off and run a hair dryer over the power supply for a few minutes then switch on,if it comes up fully working then you have to isolate the faulty part/parts and replace.
Oct 01, 2009 | Polaroid FLM-3732 Television
Hi, I need the diagram of sony tv KLV-30hr3. Thanks
i have sony klv-30hr3 working order i want to sell screen broken or to buy onether one good screen to buy pls if any option give a text thank u 07916576125
Feb 20, 2009 | Sony KLV-30HR3 30 in. LCD Television
Sony TV klv-s23a10 ...how to get over the air tv reception with in door intenna
Hi and welcome to FixYa,
This model is a monitor unit, it does not have a TV tuner and therefore no antenna connector/jack.
Good luck and Thank you for using FixYa.
Jan 10, 2009 | Televison & Video
Sony KLV-S23A10 23 in. LCD HDTV Logo
527 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
