Question about Stoves Newhome ECH600MXa Electric Kitchen Range
Have replaced the facia on my Stoves EFA600H oven , but the red indicator does not light up any more , so any advice about the back of the panel ?
bigg t
  • 640 Answers
SOURCE: stoves newhome
the residue is the grease being exhuasted from the oven.i wouldnt think you could vent it out unless you have an overhead hood.if its really bothersome look at a home depot/lowes for a heat/fire resistant filter and install it on the oven somehow.
Posted on Jan 06, 2008
SOURCE: My Stoves EFa600H inner glass recently shatterd
Hi Sorry- i do not how to do this BUT the eaxct same thing has happened to us! Cna i ask where you got the replacement glass, how much it cost and how long it took to deliver?
Thanks
Posted on Jan 27, 2010
  • 3 Answers
SOURCE: i need to replace the top oven thermostat control
you dont need to remove the front panel, you need to undo the two black screws on the side of the hob unit, remove the two plastic plugs they went through allowing you to raise the hob, and remove just the back off the cooker this provides you access to all the areas you need you can then follow where all the cables go oh yes nearly forgot the thermostat is held in place by two screws you simply pull the knob off and there they are. ive just done the fan oven one and it seemed fairly straight forward, but please do remember to turn off the power to the cooker first all the connections push on using spade connectors, oh yes for legal reasons this is for information only and i wont be held liable for injury or damage caused by unqualified people following this information to fix it themselves as i would always have to recommend that you use a competant person ie a person who is trained, experienced and has sufficient knowledge to do the job, but those that do want to fix it do so at their own risk and i hope all goes well with getting the problem fixed
Posted on Mar 27, 2010
blackmar
  • 235 Answers
SOURCE: Morning I have a Stoves EFA600H
The electronic clock/timer must work correctly and be in manual mode for the oven to work. It sounds as if you need to replace the electronic clock. If you do not need the clock function it is fairly easy to bypass the clock altogether and the oven will work no problem.
Posted on Feb 24, 2011
SOURCE: dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Posted on Jan 02, 2012
Morning I have a Stoves EFA600H electric oven and whilst the hob still works ok the clock and oven do not. The clock did start flashing last week and now has gone completely - any...
Feb 23, 2011 | Stoves Ovens
I require a new rubber door seal for my electric oven stoves newhome efa600h. I cant find who stocks them
If you try www.buyspares.co.uk not sure if they do specific model but might do a universal seal for stoves
Feb 22, 2011 | Ovens
Instruction manual for stoves newhome EFa600H fan oven
hi Ali, do you have any photos for this cooker EFa600H? I need front of this cooker. because i have in my new home but i can't used this apliance because all numbers ale clean, someone clean this oven very very strong and remove all signs:)
cheers, marce
Oct 04, 2010 | Ovens
Dhow do i remove stoves efa600H oven door hinges?
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Stoves Newhome ECH600MXa Electric Kitchen Range Logo
138 people viewed this question
Top Stoves Kitchen Ranges Experts
paulcarew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
