Question about Carrier 38CKC060 Air Conditioner
MY OUTSIDE UNIT IS NOT TURNING ON EVERY TIME I TRY THE BREAKER POPS OFF
  • 10,515 Answers
Ok --- what it sounds like is happening here is that your AC compressor is shot. One way to trouble shoot this to verify for sure is to go outside to you AC disconnect, pull the handle out of the disconnect, this will isolate the unit from the breaker, or if this is a breakered disconnect, shut the disconnect down, then turn the breaker back on. If the breaker holds (meaning doesn't trip) then you will have to call out an AC guy to verify 100% its the compressor motor and have it replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 22, 2010
Not cooling
are you talking about a central a/c system? the fan that blows is the indoor air fan? check breakers for outside unit. one breaker in the house panel box and a breaker at the outside unit. because other wise tha cap or contactor (for the outside unit) may be bad. both of witch may keep unit from turning on. unless you are knowledgeable about electricity I would not recommend opening the outdoor unit. you could get electrocuted. safety first
Oct 11, 2015 | Heating & Cooling
I have a Goodman CPE30-1AB (Outside heat exchanger), with a Goodman (air blower) as well. Air blows inside, but not cold. Outside unit is not turning on at all. Can you please assist?
check your breaker or fuses at outside unit. verify you have 24 volts feeding outside unit replace outside unit contactor if you have the 24 volts and not starting.
Aug 08, 2015 | Goodman Heating & Cooling
Indoor unit working ,outdoor unit fan and compressor won't start
Tell me more. But first "suspect" is a bad power relay. But are you sure the breaker has not "popped"? 2. 24vac transformer for thermostat signals is out. Does it have power? Could be on the same circuit as the outside unit (condensing unit), or another one that may have "Popped" First one will be a 220vac breaker, the second one will be standard 110vac. If you find a "popped" breaker and it pops again when you try to reset it, you need to call an electrician. Or HVAC technician. Be prepared for the worst.
Mar 12, 2015 | Heating & Cooling
All electric apt 5 year old fan wont turn off when air is off
Sound like bad mercury switch or time for a new thermostat would be my first guess, second guess would be that the condensing unit needs to be cleaned out side. it might be frozen up, that happens when it gstarts getting hot outside.
It might also just be as easy as flipping the breaker to the unit to allow it to reset and turning it back on. but if its still cooling and just wont shutt off, my guess would be thermostat or lose wire in there of.
If you dont have a maintenance guy you can call and it is too cool, try turning the breaker off at night until you can get it looked at.
May 29, 2012 | Heating & Cooling
Outside unit is not turning on but the inside unit is
I would check the fuses or breaker to the outside unit.
If nothing (either the fan motor or the compressor) is running - chances are you have no power to the outside unit.
It's also possible that your low voltage wire from the inside t-stat has been 'cut' or 'chewed into' (by a dog), but my guess is the fuses/breaker.
Jun 05, 2011 | Heating & Cooling
We have a 6 year old air conditioner Byrant 591B. The outside unit is not working it make a slight hum when the thermostat is set to cool, but the fan does not run. The furnace is working fine
You picked the wrong picture...lol. You have a split system and that humm you hear comes from the contactor. That means the thermostat is asking the compressor which is outside to come on. If you hear the humm but nothing is working, Check the breaker and then replace the fuses in your fuse box by the condensing unit, or the outside unit if the breakers are OK. It should have a disconnect between 3 to 10 feet of the unit depending on your codes and city requirements. No matter what, if you stand at your unit and look at the conduit, it will lead to your electrical disconnect. It could be a sub-breaker or fuses. It is usually fuses because a breaker could take up to 6 sin waves to respond as where a fuse could take only 2 sin waves. Replace both fuses. As time goes on, fuses become warn from constant load changes and heat and sooner a latter, they just wear out like any other component. Change the fuses and fire your unit back up. If it pops the new breakers, you have other issues and it's time to call an HVAC guys.
Sep 28, 2010 | Bryant 462AJC021BA Air Conditioner
ON excessively hot days, the outside heat pupmp trips the circuit breaker. Most times it is only once, I turn the breaker to "on" and it works fine. Some days it pops two or three times. When the outside...
Hello I would add a HARD START KIT to the run capasitor (if there is not one already).This makes the compressor come on easy.If the breaker trips during running time the pressures are too high,hose off the condenser coil (fins).The unit might be slightly overcharged but I would be careful before adjusting the freon at all.
Sep 02, 2010 | Carrier 38CKC036 Air Conditioner
Fan motor comes on, however, when a/c is turned on, breaker pops
If the unit is working fine in heat mode and in fan only mode, you have a short in the wiring going to the ouside unit. If it were a fan relay, then everytime the fan came on the breaker would trip. But either way, there is a low voltage short taking place in the unit. If the compressor was bad, the indoor unit would run fine and would only blow the breakers to the ouside unit. I had a unit last summer that did the same exact thing. After I replaced the control wiring to the outside unit, everything worked like a charm. Good luck!
Apr 04, 2009 | GE Heating & Cooling
A/c unit not working. Have thermistat set on 65 and temp. in house is around 85. check the breaker box for the house and it have not tripped
You must make sure that there is power to both the inside unit and outside unit. Is the room air blower blowing? If not you have either a plugged filter, iced up coil, the access door is not quite closed or there is no power to the unit. Is the outside unit fan turning? If not, you either have no call from the thermostat, the fan is broken or the unit has no power to it. I would turn off the breaker to the inside unit and switch the breaker near the outside unit to off and let them sit idle for 5 minutes. Switch both breakers back on and chect to see if the outside unit turns on. Then check the indoor unit and see if this starts blowing. Let us know what you find.
Jul 23, 2008 | Heating & Cooling
Carrier 38CKC060 Air Conditioner Logo
42 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
