Question about Ariete Cafe Retro Espresso Machine
I purchased the espresso maker above. My problem is the strength of the espresso brewed. It comes out strong at first, but by the end of the dripping it turns watery. By the time the dripping stops the whole pot is watery- tasting more like strong american coffee than espresso. I have tried both Thermacream filters, getting the right amount of coffee measured, and starting the brew by waiting for the temperature to be rightby waiting for the indicator light to go off before pushing the brew button. I reside overseas and ordered the machine online. There is no service center here ( Dominican Republic). The machine is brand new. The former espresso machine I had automatically stopped dripping at the right strength. Please advise.
  • 69 Answers
To have a good espresso depends from many factors, first of all is the coffe blend, the grind, then water quality, espresso maker pressure and temperature, and that is just the most important!...I think you can try with a REAL espresso blend with very thin grind, let the water flow without filter, then when the light switch on put the filter, you can also try to warm first for steam and after commute to make espresso and wait for right temperature. Finally you will obtain a discreete espresso, never as in the professional machines!...otherwise you have to invest such 2000 euros for a professional good coffe machine
Posted on Jun 01, 2014
2 Suggested Answers
geox29
  • 65 Answers
SOURCE: Flashing warning light comes on after about 30seconds
If the heater is bad the machine will never reach the temperature so the light will never be on.Make sure if you open your steam knob to have some water coming out and feel if the water is warm or cold.Some machine have a thermostatic switch inside for protection..I don`t know specifically your machine but they all work about in the same way.
Posted on Jun 18, 2008
Service center
Have you cleaned the outlet behind the brew unit? It is a trapezoidal shaped small hole below the plunger window. It gets clogged easily. Squirt some water into it and above it. It should come out clean. If it's clgged the water backs up into the grounds
Dec 10, 2012 | Solis Master 5000 Espresso Machine
My EM100 Espresso Maker will not brew? Water comes out when no portafilter on, but not when filter on for brewing? Help!!
This is a complex problem. 1. remove, check and clean brewhead (round screen above portafilter where water comes out); it can become clogged with gunk. 2. brewhead gasket may be old or damaged, they can be purchased on eBay. 3. brewing basket may have become clogged, I don't know if running cleaner solution through it will help, may have to replace it. 4. Likeliest source of problem is coffee ground too fine and/or tamped down too hard. These are not professional level machines and cannot work with very fine grind or heavy tamping. Try a coarser grind and a light tamp with the larger brew basket. Coffee must be ground with good quality burr grinder for correct consistency. John Saxon/
See my espresso-making blog at motophoto.posterous.com
Dec 15, 2011 | Cuisinart EM100 Stainless Steel Espresso...
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Cuisinart Brew Central 12-cup Coffee Maker Filter Basket Anti-dripo has come unattached. We have a spring and the anti-drip puiece. How do they go together?
Hello tfsmithcambr,
You need 3 pieces. The bottom plug, the spring, and the collar. Slip the spring over the plug. Insert the plug into the basket end. Slip the collar onto the inside the basket end of the plug shaft until it clicks. Should be good to go. If this does not work or you are missing a piece, you may need a new basket. Hope this is helpful. Good luck and kind regards, NormanZ
Jul 07, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Weak Coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Mar 02, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
How to set the coffe maker to brew at a certain time.
After setting the clock to the correct time .
then Press the Set delay then the HR and Min you want the timer to come on.
Press the brew strength for your preference.
then press the Select Twice to change Led light to Daily Brew. and now it will come on at the selected time.
Nov 26, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Ariete Cafe Retro Espresso Machine Logo
79 people viewed this question
Top Ariete Coffee Makers & Espresso Machines Experts
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Ariete Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
