Question about Whirlpool LER5636P Electric Dryer
Extreme heat comes out from behind dryer a orange glow is in the dryer vent could this be fire
  • Whirlpool Master
  • 2,286 Answers
That's the glow from the heater,this is normal.the dryer should be cleaned if it's electric i would clean it every two years,you need to clean out the duct that the lint filter slides into,vac out the inside of the dryer where the motor is and disconnect the vent line from the back of the dryer and clean out the vent line,if it's a long run to the outside i use a leaf blower to blow out the vent line,make sure the outside duct is clear also.if you do this you wont have to worry about a fire,your clothes will dry on time,you'll save electricity and your dryer wont run hotter than normal and your parts in the dryer will last longer.let me know how you make out
Posted on Aug 29, 2010
Fisher & Paykel dryer orange glow under dryer while operational.
gas driers use a flame to heat the drum for the drying so there will be a flame some where in the unit
when in doubt get in a technician to check and /or repair
Jul 13, 2017 | Fisher Dryers
Kenmore 700 series dryer problems
This could be a few things. The first thing to check is your dryers vent, make sure its not clogged and check were it exits the house because sometimes nest are made in them. A clogged vent will prevent proper drying because the moisture can not escape and/or the heating element turns off due to overheating.
If the vent is clear, with dryer empty open the door and hold down the door switch (button that tells dryer door is closed) and turn on dryer, as its running watch the back area of drum were the vent with little holes is, within a few seconds you should start to see an orange glow in that area. If the orange glow starts then disappears within a few seconds it means your vent is clogged, if there is no orange glow at all then you have either a bad heating coil or bad high limit switches. I believe youtube has great how to videos on how to replace them, its not that hard if you have basic repair skills. Hope this helps you and your able to get it drying agian
Dec 23, 2013 | Dryers
Sears dryer back left vent has an orange glow form heating element is this normal bought in May of 2012
Yes, this is normal for the element to glow orange like this. It's getting full 240 volts and good heating.
Dec 01, 2012 | Dryers
Lg dlg7188rm - My dryer is not getting hot. When I start a cycle the ignitor comes on (orange glow under dryer) and then gas comes on (blue glow). After about 30 seconds both shut off.
There are two or three sensors in the heat exchanger and another one or two in the fan housing. Check them all for continuity. One in the heat exchanger is resettable
Jul 22, 2017 | LG DLG7188 Gas Dryer
No heat checked all vents and gas lines. don't know whats next?
A gas dryer uses a electric igniter that glows orange to light the gas burner. If the igniter does not glow orange when the dryer is started..replace it.
Jan 12, 2011 | Kenmore 74602 Gas Dryer
I have a Neptune Gas Dryer that stopped heating....but still goes, is it worth fixing?
If it's only a few years old, it would be much cheaper to fix than to replace the unit. Chances are it only needs a new igniter and you'll be saving lots of hard earned dough fixing it. Easy things to check on your own include: Clean your filter. Clean out the vent behind the dryer. Clean out the vent outside at the vent cap. Turn on the dryer and see if the igniter glows orange. If it doesn't, it may just be broken and need replaced. Good luck.
May 15, 2010 | Maytag Dryers
Dryer won't heat up
When is the last time you cleaned out the dryer venting? May be a blockage that is causing the no heat problem. Check directly behind the dryer and also outside at the vent cap. If it's a gas dryer, it will not have a heating coil. The gas burner lights with an igniter. Does the igniter glow orange when dryer is first turned on? If not, it may be broken. Look for broken ceramic piece below where it attaches and replace. Do not touch the ceramic piece on the new igniter, as it is very fragile.
May 15, 2010 | Frigidaire AGQ7000E Gas Dryer
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
My Electric Dryer's Heating Element Glows orange while in use
Hi. this is quite normal when you dry heavy items. the dryer has sensors inside the compartment that will sense cotton and wool garment. if needed, the thermal regulator will adjust the element to the appropriate range. If there is a problem, the electronic thermal fuse will blow. this is the safety feature that will trigger itself if a fire or over heating is sensed. Also, if your selector knob is set to a cotton or high heat mode, the element will normally glow intensively during this cycle.
Please rate and god bless.
Mar 19, 2009 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
128 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
